Nature of the problem : Error appears at 1 hr & 45 mins of the burning process . The first time was all OK . The Dvd was finish but I do some changes to the proyect, I start again the burning process and from that I always have the error at 1:46
Properties of your source files : Mostly Mpeg 2 Menus & Videos from Sorenson Squeeze Vers 4.2 (Proyect Total 3.6 Gb)
What devices are involved and their mode of connection: PC Intel P4 & SONY DVD RW DW-U14A
Project Settings: DVD Video High Quality (Preset from Program)
Output format:DVD
NTSC
Error Codes: 8004138d
Error 8004138d
It certainly sounds like there is a fault on your input file, assuming you have adequate amounts of space on the disk/partition set for your temp files. As a general rule, with a default installation, you need at least 10 Gb free on your C: drive after installation.
Many MPEG-2 files have errors that don't appear for straightforward playing but are unacceptable for burning to a DVD. These often revolve around interruptions in the GOP sequence.
Hope this helps for starters.
