skier-hughes wrote:If he's captued with his media centre he'll have dvr-ms files, which I showed him how to convert to wmv files.
As Steve has mentioned we do need to know the whole process and the file types used.
The Recorded TV was made using the Windows Media Center program supplied with my Media Center PC. When looking into the properties of the files themselves it shows Microsoft Recorded TV Show, which I assume is the dvr-ms filetype you are talking about. All of the files are on average an hour long and vary between 3-4GB each.
All of the filetypes are the same.
The process is carried out using the DVR 2 WMV program mentioned on your website skier. I have followed the instructions carefully and have only opened the mentioned DVR 2 WMV Standalone version to convert my files. Before starting the conversion, the settings for the process are as follows.
Encoding Quality - PAL VBR
Choose Prefered Decoder - (No x) Video, (No x) Audio
Compatibility Mode - Yes
Save Closed Captioning - No
Priority - Normal
Save File As: Title-Subtitle.wmv - No
Reverse Title In MCE - No
Delete File After Converting - No
Enable Logging - No
Choose Output Directory - (Set as Desktop)
Also I have noticed that when cancelling a process and then trying to restart it again, it displays the following error message.
As you have media centre, you could use movie maker to edit and then go through to the built in dvd recorder programme.
This doesn't appear to be an option, certainly not in my version of Windows Movie Maker. It just simply won't import the file.
Oh...and just to make this clear, this is not a standalone Media Center, it is a Media Center PC running Windows Media Center 2005.
Thanks very much for looking into this, much appreciated.
[b]Computer:[/b] Windows Media Edition, P4 3.0Ghz Processor, 2.5GB RAM, USB 2, Composite, FireWire 1394, SVideo, External HDD 150GB, External HDD 2 - 500GB, Internal HDD 250GB, Ati Radeon X600 256MB Graphics.
[b]Cameras:[/b] Sony HDR-HC1, Sony DCR-HC85E
