Compliance for replication issues?
dax702
Post by dax702 »
A little background. We're a small publishing company which sells instructional DVDs, 15 of them to be exact. For the last few years it's been small potatoes duplication. I've been using DVD Workshop since the get-go (version 2) In the near future I anticipate having to go to replication for the large quantities. I'm not very technical so I'm trying to get the bottom line on DVD Workshop 2 authored projects and replication test errors. I've saved all the projects to image files. All the projects are standard DVD-5. Will I be able to use these files/discs for replication? I'm hoping I don't have to hear that I have to go back and re-author all 15 of them in a different program in order to pass some test for replicating.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
I do loads of duplicating, (burning) from just a few to thousands and have discs come from all types of apps and customers. As it's just a question of copying them, it makes no odds what is made to make the disc.
Replication or glass mastering woukld be no different. Some places may ask for the work to be on DLT, but this would be too expensive for you to set up, so search for one which offers replication from disc.
Any errors on the disc you supply will be replicated on the copies, but good places should test the disc before copying to ensure all is ok.
DVDDoug
Moderator
Post by DVDDoug »
I wonder if the replication house has some sort of validation program?
I'm not a professional, but I have a really good reference book called DVD demystified. I don't have it with me right now, but it has a chapter or section about what to look for... maybe a checklist... before sending out your master DLT.
In general, I find it useful for for looking up stuff like what bitrates are valid, or unusual stuff like what MPEG-1 formats are valid. There is some history of video "nonsense" in the book too, but most of it's 700 pages are solid technical information, and technical recommendations.
So far, I haven't run-across a situation where Workshop did something that the book says is invalid. (Except, maybe It did allow me to put MPEG audio on an NTSC DVD...)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
dax702
Post by dax702 »
Interesting... I'm just hoping I don't have to reauthor 15 DVDs in a differet program because they get rejected by the replication plant for not passing some test....
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
If you've made it to dvd standards, NO YOU WON'T. :wink:
Graham
dax702
Post by dax702 »
well I've made it to whatever DVD Workshop creates the DVD as.
I mean, my source files are NTSC, MPEG2, AC-3, the whole shabang haha
But as far as what dvd workshop puts out, that is what I am asking about
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
For a definitive answer then you'll need to post your settings for the mpeg2 files and the ac-3 audio for each individual disc, unless you used the same ones for all 15.
dax702
Post by dax702 »
well I didn't use the same settings for all the files, but they are all still NTSC standard,,, I used diff bitrates, but within the spec
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
dax702 wrote: within the spec
Then you will have no trouble getting them replicated.
Replication and duplication are both just copying the disc you supply.
When I said test the disc in my first post, the better quality duplicating machines used for burning several discs at a time, such as I use, do a dvd test first to ensure that the disc will play properly, before commencing with the copying.
dax702
Post by dax702 »
ok that's a relief..
