I have just purchased vs10plus - used search function & think I have the correct answers - just like a confirm.
If I understand I can retain my vs9 and also add vs10 plus without causing any problems - just let the install procede according to disc? Also, I believe that all my vs9 files will import into vs10plus. Once I import will I loose the ability to use vs9 on the files? Can I save the files in vs9 on another hard disc - and delete once I am sure that I can operate with vs10plus?
Am excited to move up - just a little nervous about the new version. Have had little problems with 9 - but really want the additional features from 10plus
Petrea
videostudio 10 plus (leaving vs9)
Tales 68 - - I would strongly recommend that you do NOT uninstall version 7 until you have version 10 installed and running - you may need to 'nip back' to 7 to refresh your memory or to transfer clips and templates from 7 to 10.
You can uninstall 7 later if you really want to - but they will co-exist very happily on the same machine.
