Dropped Frames
btesnar
Dropped Frames
Post by btesnar »
Can someone tell approx. what an acceptable amount of dropped frames is for a standard 1 hour Mini-DV tape capture? As I am capturing tapes, I seem to be getting a somewhat varying number of dropped frames per tape. Also, does using your pc for other tasks during capture affect frame dropping.
Thanks!
HP
AMD Athlon 3700
1.0 GB Memory
200 GB Hard Drive Capacity (used = 34 GB)
Windows XP SP2
Ulead VS 9.0 w/ all relevant updates
Sony HandyCam Digital Video Camera DCR-HC20 NTSC
I regard zero dropped frames as being the acceptable limit. In the past, I used to get them when I started a capture -- just a handful. But as I always started my captures before the section I was interested in, to make sure I got the exact start of that section, I knew I would be cutting out the section with the dropped frames anyway. I also tended to put the dropped frames at that time down to my klutzy initiation of the capture process anyway.
There is a tiny, freeware program, WinDV, which you can download. It only does captures (and exports back to camera). But it seems to be able to handle it with no dropped frames. So try capturing with that, and then import that captured DV into Video Studio for editing.
heinz-oz
Post by heinz-oz »
As Ken said, Zero dropped frames is the maximum I would accept. I have captured many a one hour tape with no dropped frames at all.
Having other tasks running may influence the performance of your PC. What is the platform you capture on? Notebook? Check if UDMA is enabled for your HDD. I take it you are capturing to DV-AVI?
bop
Post by bop »
May i also assume connecting with firewire/ilink/ie1394
Brian
Video Studio X-3
LG BH10LS30
LG GH22NS50
TDK1044
Post by TDK1044 »
With your system you should see zero dropped frames. Disable programs such as Screen Saver, Anti Virus, Spam Blocker etc during capture.
Terry
tommytucker
Dropped Frames on Capture
Post by tommytucker »
Had numerous problems with getting quality capture with VS. Fiddled with settings for too long, VS frustration started setting in. I am sure that I did not have some certain setting quite right, but wanted to get the job done and start editing. I agree that WINDV freeware program is wonderful for solving this capture issue. You would think Ulead would just buy this guy's program and make it the capture module for VS, works great, easy to set up and understand and not problems with capturing from Cam.
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
dropped frames
Post by Ken Veal »
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=15677
have a look at above post, it may be of some help
