Adding Tekst file
Adding Tekst file
Is it possible to ad text files as introduction in a movie. Description of the movie that follows. Saved as .doc or .
txt
You can use the titler, which will accept a txt file (up to 5 kb).
It is better to use a vector graphics app, rather than a bitmap one. I use Corel Draw! in text paragraph mode. Use a fairly uniform sans-serif typeface, such as Arial or Tahoma. Avoid typefaces with serifs, such as Times New Roman or Americana. Avoid, at all costs, those with thin strokes, such as most scripts. Select a paragraph width of, say, 200 mm. When you have composed your text, you then export it to TGA (if you wish a transparent background) or BMP format at 150-200 pixels/inch with anti-aliasing selected. Do not use JPG or GIF. Import it into MSP as an image.
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Actually, pixels/inch are meaningless unless you specify the paragraph width as well. I'd go for 300 pixels.inch for a 4-6 inch wide paragraph. What you really need is a paragraph width of, say, 1200 to 1800 pixels. Whether this is 15" wide at 100 pixels/inch or 2" wide at 750 pixels/inch is not material. When reduces, with anti-aliasing to 720 or 704 pixels wide, it should look good.
