error message with gif animator
GIF Animator, SmartSaver Pro, Plugins, Applets....
mzkatz
Post by mzkatz »
i paid for this programme and every time i open it up to start using it i get the same error message ive posted the troubles here for you to view and hopefully someone from here can help me
http://groups.msn.com/CommunityFeedback ... 6590812020
heinz-oz
Post by heinz-oz »
This is a well known, standard Windows message, people get with all sorts of programs. When Windows doesn't know the reason for the problem (it never does) it spits out this nonsensical message.
Check your memory for errors, make sure your HDD is defragmented and there is enough free space in the location of your temp files.
I had the very same error message yesterday with PI 11. After I applied the SP1 patch to it, this error went away.
mzkatz
Post by mzkatz »
ive sone several re-starts and turned firewall off and then also viral check
i will try the defrag
and also i may try to see what happens when i install it on my laptop
VikingAnimations
processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
ram: 4 GB
Hard_Drive_Capacity: 1 TB
Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Post by VikingAnimations »
Judging from the screen shots in your post at Community Feedback, it looks to be the infamous Video Codec problem.
You can either try the solution stickied at the top of this forum:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=12369
OR....
In Windows, click Start, then Run.
Type "regsvr32 /U 3ivxDSEncoder.ax" (without the quotes) and click OK to unregister that offending codec.
mzkatz
Post by mzkatz »
thankyou so kindy we sure could use you on my psp group i have
not the community one as thats one im just a member of
