Steve,
I know you are trying to help people.
[MODERATOR MESSAGE: POST EDITED, PLEASE READ FORUM RULES HERE: http://phpbb.ulead.com.tw/EN/viewtopic.php?t=5758 THIS IS YOUR FIRST WARNING!) I have burned, sold over 200 DVD's, with 16X TY media; without one return. I used to have problems, burning with cheap, or up to second grade media. When I use good blank media, my DVD players; play them all, regardless of fromat; DVD-R, +R, -RW, +RW, DL+RW. If you buy top quality media, you will see. Steve, have you ever bought top quality blank media? I bought DVDR's & CDR's when they were over $10; so I can't see why you say a $1.50 DL DVD is expensive. DVDr's were around $2 apiece, when Ulead VS7 came out; unless you bought some cheapos, which I have done.
I render my AVI's to DVD's @ 8000 or 8200, CBR; without ever having a problem. I save my work to ISO files, so I won't have to render again.
I also compared saving ISO files, to VOB files; and I could see the difference also. The ISO saved files, were close to the original. The VOB files showed more compression, poorer quality.
I first used Ulead, to make the DL DVD, after rendering and making a ISO file. When the DVD was finished, the DL DVD played on all my DVD players. The menus were correct. Did you hear that Steve; I know you are not too technical. I'll repeat it again 2X, so you can read it;
It played on all my DVD players. But, the chapters 6-10; played chapters 1-5 instead of 6-10. Steve, changing the bitrate, burning speed, will not change the data, of what is burned on layer, it shouldn't take a Einstein to figure that out.
I then burned the ISO file, that I made with Ulead; but using Nero6, and got the same exact results.
Also MM, when I used to buy cheap blank media; it played on some of my DVD players, not on others, skipped, froze. And like you, the cheap media worked better in the cheap DVD players, and had problems with the two +$500 ones.
What I'm trying to tell Steve, is when you have a bad burn; your DVD player will not play normal. It will skip, jump, lockup, show no media inside, etc. or freeze. If Steve thinks, that slowing the speed of the burn rate, is going to change the ISO data that is written, to layer #2; to show chapters 6-10; he needs to get a book on how data is written. Again, and I will say again (2X speed for Steve); I have, and so did everyone else; have
NO PROBLEMS burning DL DVD's with OTHER software programs, at any burning speed. DID YOU READ THAT STEVE... using their ISO files, or direct to DL DVD. Same burner, same media.
Steve I got something for your slow burning procedure. I'll burn my 8X DL DVD+R one time, using the same ISO file made with Ulead @ 2X speed; and if it works, I'll send you 10 TY, DVD-R blank DVD's. But, If I get the same result; you send me $5 via PAY PAL.. How about that???
Bet???
Go here to find the best Media:
http://www.best-dvd-burning-software-re ... asp#blanks
By the way Steve, is your media listed here, and what do you use?
Rich.
