Sjj1801: yes, *all* ( what a loaded word that has become ) I want to do,
is get quality avi into my computer.
Heinz observed that my original post was long. He was right. It was long, and
the reason was, I had just spent about 5 hours researching and after partial anwsers to partial questions from several forums I needed to be thorough.
In it, I wrote that USB 2 was out of the question since many had remarked that over time the audio video synch falls out. Also, I had mentioned that I didn't want to use up a PCI slot. The reason being, PCI slots are funny things, in that they sometimes share IRQ settings with other elements of the computer. This is the extent of my technical knowledge, and I learned this because I freaked when I put an innocent USB 2 card into my PIII computer and it booted up in Safe Mode!! NOT GOOD. Thankfully I tried my last available PCI slot and it just happened to work.
So, I thought...no pci slots on my new computer because I already do pro audio on it. But the Asus motherboard comes with a Firewire slot! Great.
Tried the awful Dazzle 90, which installs drivers. Well, that software killed 2 computers. Mine and a friends. After removing the software, neither of my cdrom drives showed up. I found a fix after 2 hours.
Then, I read about the Canopus. It seemed ideal. No drivers, conversion outside of the pc, firewire in, superb reports......except.......it encodes to Mpeg 2.
And for the reasons you stated, I did not want to be working with mpeg
2 files, only avi...so I could do some editing.
I heard the good things about the Hauppage....and, it's looking like I may have to go that route.
Maddrummer: I live in Canada, so, by the time the Canon gets here, after duty, taxes, shipping etc...I'll be up to $600. Might as well buy locally, then I can get a return if the image quality isn't up to scratch. Thanks for the link anyways.
No disrepect intended here at all Maddrummer, but, I've done some research, and when you here 30 different people say, "yep, motornoise,
nope, mines fine" over and over again...you can bet as someone said,
it's a bad batch. It happens. Tigerdirect sells some of those 'bad batches'
my Asus motherboard was one of them. So, I need to go local should I end up with one of those Canons.
Jeeeeees, how hard can this be. Honestly.
I want a box, outside my computer, no pci slot, firewire in, good quality image, to transfer my VHS to avi. That's it. And I can't find it for around $400.00 Canadian. This is getting silly.
I think I'll call up the folks at Canopus and ask if their little unit ( which
has received rave reviews, but apparently encodes in mpeg 2) has an
option for avi. Is doesn't state so on the site. But, who knows.
If not. Well, I'll take my chances and grab a Hauppage and use up a pci slot and prey it doesn't interfere with another IRQ setting.
Thanks guys.
