XviD/MP3 encoded .avi
PAL format
512 x 384
25 frames/sec
I drop the file into the timeline and select "Clip" and it plays and seeks fine. I select "Project" and if I play it from the beginning, there are no sync issues (that I can tell). However, if I seek ahead and then hit "Play" or if I use multi-trim etc., then it becomes out of sync (the audio is about 3 seconds ahead of the video).
Also, whenever I try saving this file (not that it makes any difference to the sync issues, anyway
It's worth mentioning, I suppose, that my codecs initially came from a codec pack a couple of years ago (and I don't think I've updating many of them manually since then). However, since I can play this file without trouble and since Ulead can play it and read all the codes and other file info properly, I can't see how this can be an issue. I also looked at the file in G-Spot and it tells me that the required codecs are installed and the file properties it gives me match up with the ones Ulead reads.
Anyway, does anyone have any suggestions? This is driving me pretty insane.
