Videostudio 10 Plus audio problems
zydec
Post by zydec »
Can anyone help me please?
Using vs 10 plus, I import from a dvd recorded from a standalone dvd recorder, but when I drag that video into the timeline and play the clip it's fine. It's when I playback the project. I'm getting some crackling noise in the background and when near the end of the video the audio and video are out of sync.
PAL DVD
720x576 25fps
AthlonXP2600
1 gb ram
120 gb Maxtor hdd x2
128mb asus v9560 graphics
asus dvd burner
Please help
Zydec
Reactor
Post by Reactor »
I just had that happen, and I think it's because of memory issues... or cpu issues when playing back the rendered avi file. It's trying to find places in video while going from cut-to-cut, and I don't think it can seek fast enough, which is why you wind up with out of sync video and crackles in sound. If you hit pause and play from the area with out of sync video, does it fix the problem temporarily? And, do you have the same issues if you're using proxy files?
zydec
Post by zydec »
It's actually a mpeg file I'm trying to look, I haven't done any editing of the file. I just import, put it into the timeline, it's when I playback the project I get the problem not when just the clip is played.
Never used proxy files.
Zydec
daniel
Post by daniel »
Preview if set on Instant Playback (Preferences) is just a preview.
Not the actual output and the displayed result is an approximation to help you see how everything works. It's quality is determined by your computers' capabilities and the other applications running.
You can't judge the quality until you really render the project.
Consider it a draft...
zydec
Post by zydec »
I know it's a draft.
But I had it working fine, I didn't use my computer for a couple of weeks, then it started going funny. I didn't change any settings. One minute is was working fine then the next it went funny.
I have vs9 on a completely different machine and that done the same too, once it worked then the next it didn't.
I can't concentrate with this heat now aswell, I think going funny myself.
Zydec
Post by Black Lab »
What happens if you burn it to a DVD(RW)? Same results?
zydec
Post by zydec »
yep, burnt it to a DVD+(RW)
same results, jerky video and audio going out of sync
Post by Black Lab »
OK, now you are saying jerky video too...
Are you following the Recommended Procedure in the top sticky post?
Please list the properties of your clip (right click on the clip) and your project.
zydec
Post by zydec »
I'm doing what it says
i have imported video and edited before, but for some reason the video is jerky and audio goes out of sync ONLY when the project button is clicked, when the clip button is highlighted the video works fine
Zydec
DVDDoug
Moderator
Post by DVDDoug »
...Sounds like a bad MPEG to me. It could be that the DVD is damaged or dirty, or for some unknown reason Video Studio is having trouble importing it. DVD importing seems to give lots of people trouble. A bad MPEG can be difficult to diagnose, because it will often play-back OK, but cause problems with editing programs, or when re-coding or re-multiplexing.
With a different video file, right? If the same MPEG file is no longer working, maybe you did something to mess it up??? Try re-importing it.
I don't know what the solution is... As a last resort, maybe analog capture if you have the hardware to do it.
I doubt that this is caused by a hardware or operating system problem. Your computer is just "number crunching" digital-data. A slow, underpowered, computer can get errors with real-time capture, but once you have digital files on your hard drive a slow computer is just slower... it doesn't make errors. It is also unusual to get a true "out of memory" error, because Windows automatically uses the hard drive as virtual RAM. It's waaaaay slooooower... but again, that's just a speed issue.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
zydec
Post by zydec »
i know waht you're saying
i am importing a mpeg file from a stand alone dvd recorder disc
i've used different discs and files, same problem
and i've also captured the video through firewire, same again
i've installed 2GB of ram now and it's still doing it
i seem silly but i've burnt dvd's using the same settings before and why can't it do it now?
Zydec
Post by Black Lab »
What exactly is that?
One thing you can try that has worked for some people is actually copying the mpeg file to your hard drive, then import into VS from there, instead of from the DVD itself.
Other than that we are at a standstill, unless you want to give us some more info, like your clip and project properties.
zydec
Post by zydec »
project settings:
PAL (25 fps)
MPEG files
24 Bits, 720 x 576, 25 fps
Lower Field First
(DVD-PAL), 4:3
LPCM Audio, 48000 Hz, Stereo
Clip properties:
PAL DVD
MPEG-2 Video, lower field first
24bits, 720x576 (4:3)
Variable bit rate(MAX 9396kbps)
Dolby Digital Audio
48000 Hz,2/0(L,R)
256kbps
These are the settings
LV_426
Post by LV_426 »
I have exactly the same problem here. It's a new problem with version 10. Version 9 does not suffer the same thing.
I'm convinced that v10 doesn't handle DD audio very well.
The Tabletop DVD recorder is a Pioneer 520. DVDs are made on DVD-Video format and then imported using VS10.
If I record on the Pioneer with the soundtrack as PCM (the Pioneer does this only on its lowest compression setting, 1 hour per DVD) then all is well.
If I record with a DD soundtrack (any other compression setting) then, in VS10:
1: Preview audio is very crackly/corrupt, but only when playing THE PROJECT. Playing the CLIP is OK.
2: In Re-encoded files, regardless of whether it is SmartRender or a full re-encode, the audio will have occasional (say two or three times per second) clicks in it.
Sad really. I so want this software to be good; sadly, I find it isn't.
zydec
Post by zydec »
Thanks for that LV_426
I'll have a look at my Hitachi dvd recorder
Zydec
