But I have 5 slide shows...
But then I end up with 3 MENU PAGES?! Because only TWO shows can fit on a page...
Is there anyway to tell the THEME to place all 5 on one? Are there any themes that support 5? help
If you have the registered version of the program you can download 45 additional menu templates at:mcfz wrote:I am using one of the THEMES provided with PS4.
What you can do is create your show(s) with PS4 but instead of burning a DVD, go to the "2 Theme" tab and then the "Slideshow" tab and select "Save Slideshow As Video File". This will output the show (without menu) as an MPEG file in the DVD quality profile of your choice. Use the file as an input source with Nero 7 to burn your autoplay DVD. Again, this process exports ONLY the slideshow itself so you'd have to create your menu in Nero.cadillacjack wrote:Thanks, I looked all over for some updates, keep putting updates out there,
I just got my package and use it all the time. I need an auto start when you put in the DVD, is there any? I now have to press play, or tell others to press play. They would rather just put in the DVD and it start by itself like Nero 7 does. Thanks
Cadillacjack
