HELP! newbie at work VS ver 8 SE
flurry
Post by flurry »
hi guys this is the first time me using VideoStudio 8, ive made my first dvd with music clips downloaded from P2P programs.
the dvd came out fine, the clips works, the sounds are right, everything WAS good..... I CANT SEEM TO SKIP TRACKS!
can someone please help me. ive read the manual like 50 billion times! am i missing something?
HELP! :cry:
heinz-oz
Post by heinz-oz »
Could you please describe your problem again? It looks like you don't have a problem and can't believe it :?
GeorgeW
Post by GeorgeW »
Are you making an "Audio-Only" disc, and having problems selecting a track (or skipping to the next track) :?:
George
bop
Post by bop »
If i understand what the problem is it is that you have a number of music videos that you have compiled to one DVD. If you want to be able to skip to the next song when you set up the menu the start of each song must also match up to a chapter point.
Is this what your problem is and is that what you did :?:
Brian
Video Studio X-3
LG BH10LS30
LG GH22NS50
flurry
Post by flurry »
yea ive chucked a whole bunch of music clips into one dvd, and ive burnt the dvd, but when i play it on my dvd player i cant seem to skip to the next track
flurry
Post by flurry »
sorry bop
but how do i do that?
heinz-oz
Post by heinz-oz »
Have you read the manual?
With VS8, you can do it two ways. The first is to keep all your separate songs on separate video clips. When you go to the burning stage (Share> Create Disc > DVD), you then insert each of your separate clips. This way, when you create the menu, each song will have its own separate menu button, and you can use your remote control to jump between the titles, though you may have to return to the main menu to do this.
OR, if you first join all your clips together into one video file, when you go to the burning stage and insert that single file, make sure you select 'Add Chapters' when you go to build your menu. On the Chapter selection page, you will need to choose to insert the chapter points manually at the start of each new song. Then when it is burned, you use the remote control as you normally do to jump between chapters, or in this case songs. :lol:
flurry
Post by flurry »
Hi Ken Berry
thanks for that reply.
how i made my first dvd, i got to the burning stage (Share> Create Disc > DVD), and i draged the video clips in one by one, and then clicked on next till it was the final part (burning process), and the dvd came out like that. did i miss something in the settings maybe?
like i can search the tracks through the menu fine, but is there a way to skip tracks while viewing the dvd?
Not unless your videos are chapters, as I described in the second method above.
