Analouge Tape to digital vs 8
bootsie
Post by bootsie »
I am trying to convert old VHS Tapes ( analouge ) to DVD and I am using a Belkin High speed USB2 external converter. I am connecting the VCR by means of Composite connections . I am using VS8 and can only get the picture / capture in Black and white . I have looked at the capture format and have set it to PAL . When I open the dialougue box named OPTIONS I cannot select Composite because the option is not available. Hope this makes sense///// thanks
Post by BrianCee »
On the old forums this problem came up a number of times and I don't think we ever found a solution for it, other than throwing the Belkin device away and buying a decent converter.
thecoalman
Post by thecoalman »
Have you used the software it came packaed with to capture or try using something else to capture such as Movie Maker. you could import the capture into VS8.
