need help!!! sound problems
wilson99
Post by wilson99 »
hey can some one help me i have a problem, when i try to make a dvd ( import dvd files) or even copy a dvd like from my home movies i have or tv shows ect.., it never has the sound during or after the editing.
but after i add a music file to it, the music file will play during and after the editing (meaning after burned only the music file plays in the dvd player).
but when i recorded something onto the harddrive with my wintv2000 it does play the sound, but i dont have the time to record a 4 to 8 hour dvd.
i use the Ulead DVD MovieFactory 3 SE.
thanks for any help.
GeorgeW
Dolby Digital Audio?
Post by GeorgeW »
Could be your source dvd has Dolby Digital audio (AC3), and your version of MF3 doesn't support AC3 audio (decode and/or encode).
Can you tell what the audio type is on your source dvd?
George
wilson99
Post by wilson99 »
yes the sourse dvd/s are Dolby Digital audio.
so how do i fix this problem, so it will encode AC3?
GeorgeW
Plugin?
Post by GeorgeW »
Double check if your version of MovieFactory 3 SE supports Dolby Digital audio (it might or might not). The retail "Standard" version of 3.0 does not, while the Retail "Disc Creator" version does. I'm not sure about the "SE" version that you have.
Ulead sells a Dolby Digital plugin for VideoStudio 8, so they might have a similar plugin for MovieFactory 3.0 SE -- send their tech support or sales an email explaining the version you have and how you can get the Dolby Digital plugin (maybe the one for VideoStudio works with MovieFactory -- I don't know).
George
T_Scheen
Post by T_Scheen »
For AC-3 Plug-In, see also:
http://www.videoredo.net/msgBoard/viewtopic.php?t=646
I would consider the upgrade to Disc Creator instead of the Plug-in
htchien
operating_system: Mac
Post by htchien »
So far as I know, any SE version of Ulead products will not support Dolby Digital audio because of the license fee issue. And at the present time, no Dolby AC-3 plug-in for Ulead DVD MovieFactory.
If you wish to get Dolby AC-3 support in Ulead DVD MovieFactory, you will need to upgrade your DVD MovieFactory to the Disc Creator version.
Another note: if you have some other non-Ulead video/audio products like Roxio Easy Media Creator 7 installed in the system, you might not hear the audio of the MPEG video clip made by Ulead when you play it in software players, that is because Roxio will install some MPEG audio CODEC that caused the problem. But you can still hear the audio of the clip in Ulead products and use it to burn your DVDs. Uninstall Roxio will solve the problem.
Hope this helps.
H.T.
Ted (H.T.)
