I've overlapped two video clips and the default crossfade transition is automatically inserted - fine. However, I can't see how to change the transition. I know it's probably something simple but then again, so am I! I've recently upgraded from Videostudio and this used to present a window from which you can select the effect you want. Any advice would be gratefully received.
Simon.
Missing transitions
Within the Production Library all I have are symobols to do the following...
Menu
Thumbnail Display Mode
Import Video File
Import Audio File
Import Image File
Import Project File
Multi-Trim Video
Add to Time Line
... and nothing else. Perhaps I don't have the Production Library configured correctly. If not, I've no idea how to correct.
Simon
Menu
Import Video File
Import Audio File
Import Image File
Import Project File
Multi-Trim Video
Add to Time Line
Simon
