analog or digital
dipbasak
analog or digital
Post by dipbasak »
hi,
if i capture from av out of a dv cam, what will be the signal analog or digital. Kindly help me.
regards,
dip
heinz-oz
Post by heinz-oz »
Depends on your capture device, The AV out from your VCR is analog. Your PC cannot handle analog and needs a converter (capture device) to convert to digital. DV-AVI is the preferred if you want to edit, mpeg2 is the quickest if you do not need to edit. Some analog capture devices have hardware conversion to mpeg2 other do not and rely on the PC to do the number crunching. That requires a powerful machine.
dipbasak
Post by dipbasak »
Thanks heinz-oz for your guidence.
When i am selecting field order detect button to check the field order it always ( when source is vhs or tv tuner) detect lower field first.Can u explain me where i am wrong. I am using intex tv tuner card.
dip
TDK1044
Post by TDK1044 »
Ordinarily, analog footage will be captured using the Upper Field First setting. However, there are a few capture devices out there that will capture everything using Lower Field First. Check the properties of your captured files and keep those property settings for render and burn and you'll be fine.
Terry
heinz-oz
Post by heinz-oz »
As TDK1044 said already. Whatever your capture device captures determines the field order for the rest of the project. Should you get jerky playback, however, reverse the field order.
That's all
daniel
Post by daniel »
My particular capture card is reported by all Ulead software (MF, VS, MS, WS) that I tried as lower first.
But it's evidently and logically Upper first as is easily seen if I try to use Lower First.
So sometimes auto-detect is not working.
Try upper first and if it's shaky, it's the other way... Duh.
Be careful that you can only decide on a TV, preview or playing the MPG file on your PC (progressive) is not enough.
