Crop a photo into evenly sized squares?
RocckLobster
I have a photo that I'd like to crop multiple times in order to create nine separate images that, if pasted back together in a new image file, would look like the original image; almost like creating a tiled puzzle. So, the challenge is how to do it in a way that makes everything come out evenly...it looks like the crop tool only allows me to crop one section of the image; then I have to save that cropped area and then try to crop the next area, but there are no markers to tell me where I already cropped.
Any suggestions to make this task easier?
Thanks!
Thanks!
heinz-oz
RocckLobster
Hello Heinz,
I am using PI 11. Although there is a Grid and Partition menu option in the Web menu, it is disabled unless you are starting from a new file. So, using your suggestion as a starting point, here's what I was able to do:
1. Start a new file set to the same size as the active file
2. Select Web -> Grid and Partition. Set to 3 columns and 3 rows. Grid lines set to 5 pixels, black color. Option to Draw Border line is unchecked; option to convert cells to objects is unchecked.
3. Use the magic wand selection tool and click in the new grid area; right-click and Invert.
4. Right click again and choose Convert to Object.
5. Change the selector to the Pick tool. Click on one of the grid lines you just created and Copy/Paste to the other image file and you now have a nice grid overlay, which can be used for guidelines for cropping.
Thanks for the tip!
Mike
Thanks for the tip!
Mike
keenart
heinz-oz
I will check PI 11 tonight when I get home. Only have PI 10 here at work.
I have set the options to 0 for the grid line and ticked the option to convert each cell to object. By simply using the selection tool or the layer manager I can select any of the cells and shift the contents around. When looking at the original image, you don't even see the cell boundaries.
In order for the process to work, you need to have an image open.
Here is an example of the menu choice
and here of the effect when you unlock the cell from layer manager and shift it
As you can see, there are no grid lines or indications on the image where the grid lines are.
This feature is helpful for larger images on web pages, where the image loads gradually, bit by bit.
RocckLobster
heinz-oz
RocckLobster
keenart
heinz-oz
What format are your images in? I found that I cannot use this feature with gif images. Jpeg's work fine. If your images are gif, convert the image to jpeg (24 bit RGB) or greyscale if they are B&W.RocckLobster wrote:If I could figure out how to use the grid and partition tool like you demonstrated, I'm sure it would be a lot easier....
For some reason, though, it's not enabled when I have my image file open; it only seems to be enabled when I have a blank new file.
RocckLobster
The image starts out as a 24 bit RGB jpg, then I convert to grayscale. Not sure if it retains the 24 bit attribute though. I'll check it when I get home tonight; that may very well be the problem.
keenart; I'll also look into the Print Multiple and Print Poster options as those sound promising too.
Thanks for both of your suggestions and ideas!
Mike
heinz-oz
RocckLobster
I tried out the Print Poster option and it almost did what I wanted. Except for the lines that it prints on the photos (in order to trim or overlay your photos so they can be "stitched" back together to create a poster) it would have been a good option.
So, I went back to Heinz's original suggestion, using the Grid and Partition option in the Web menu. I had to start over with the original full color photo and, instead of converting it to B&W using the Convert Data Type menu, I used the option Photo->Enhance->Monochrome in order to retain the full color attribute. Thereafter, I was able to use the Grid and Partition tool and easily copy/paste the sections into new images and print them out for my project.
Thanks for all the great tips!
Mike
Mike
heinz-oz
You are welcome
Do come back occasionally to share some of your experiences with other newbees. I'm sure you would be as valuable to some soul out there, trying to get one of his/her ideas to work, as we have been to you.
I have never even thought of doing what you were aiming to do. I was just fortunate enough to remember a lesson from the beginners workshop where my suggested process was used to splice an image for use on a web site.
