field order confusion
dipbasak
Post by dipbasak »
HALLO,
I AM USING VS8. FOR ANALOG CAPTURING SUCH AS VHS OR TV PROGRAM I AM USING INTEX TV TUNER CARD. IF I DID NOT CHANGE FIELD ORDER IN PROJECT SETTING AND GET INTO CAPTURE WINDOW AND CHANGE FIELD ORDER FROM THE OPTION, DOES IT WORKS, WHAT IS THE CORRECT PROCEDURE?
PLEASE HELP ME.
REGARDS
DIP
daniel
Post by daniel »
If you do a search in this forum for field order subjects, you will find more info that you will ever need about the subject.
The important is that the field order is conserved from capture to editing to authoring. I don't know your card but analog is USUALLY upper field first.
Did you notice I used capitals only to enhance the important part?
heinz-oz
Re: field order confusion
Post by heinz-oz »
dipbasak wrote:HALLO,
PLEASE HELP ME.
REGARDS
DIP
I'm sure your intention was not to shout. :roll: . Just in case you didn't know, using all capitals is considered shouting and nobody likes to be jelled at :wink:
For the rest of your post, daniel has given you as much detail as anyone else could.
Post by Trevor Andrew »
Hi Dip
The correct procedure is to set the field order at the capture stage.
From File Preferences select—show messages when inserting first video……..
Start a new project
Capture--Capture Video—Options—set your field order here using the ‘change field order’.
Generally capturing via a tv card is analogue.
Analogue capture requires Upper Field.
Once your capture is complete you will get an info window asking you to change the project properties to match the video file, this is what you need, select yes/ok
Your project properties should be the same as your capture properties.
During capture check the ‘drop frame counter’ any number higher than zero is not good.
Trevor
heinz-oz
Post by heinz-oz »
You could have saved yourself all that SHOUTING and typing by searching this forum first.
If you did, you surely would have found this http://phpbb.ulead.com.tw/EN/viewtopic. ... highlight=
or this http://phpbb.ulead.com.tw/EN/viewtopic.php?t=15385
dipbasak
field order
Post by dipbasak »
Sory Mr. Heinz Oz, this is not my intention. Unmindfully I used cap letter.Thanks for the link ref.
regards
dip
heinz-oz
Re: field order
Post by heinz-oz »
dipbasak wrote:Sory Mr. Heinz Oz, this is not my intention. Unmindfully I used cap letter.Thanks for the link ref.
regards
dip
You are welcome and don't worry about the shouting remarks :) never thought it was your intention anyway. Hope the link information helps you. If not, come back here and ask :wink:
PS: no need to call me Mr. either :D
