Importing from DVD/DVD-VR -- I get video but no audio
Sheep Cloner
motherboard: Not exactly sure
processor: Intel Core i7 920 at 2.67
ram: 6GB
Video Card: NVideo GeForce 8600 GTS
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 2TB
Post by Sheep Cloner »
I am unable to capture directly from a 4" DVD that I had recorder on a camcorder. I end up with all of the video but no audio. If I right click on the captured file Video Studio 9 seems to think that there is an audio track present. It is a flat line of audio if you look under the audio tab. This happens in both standard DVD and DVD-VR formats.
Has anyone else had this problem? Solutions?
NTSC
Error Codes - None
System information: Hauppauge WinTV PVR PCI II, Windows XP Medio Center, 1 GB DDR RAM
Thanks for your help! ~Ken
Thanks! ~Ken
Are you importing the DVD files correctly as shown in this post:
Importing DVD Files
Sheep Cloner
ram: 6GB
I believe that those are procedures for Video Studio 8. I'm using 9. I do believe that I am importing the DVD correctly. I click on capture, then Import from DVD, then I select the VIDEO_TS folder, I choose the desired scene, click import, and wait. In both the preview and VS9 interface I get no audio.
Thanks! ~Ken
Although the Tutorial was written with version 8 it is still valid now even with version 10+
Sheep Cloner
ram: 6GB
I have double checked the procedure and followed those that you sent me. I'm still getting the same results. The video is there but the audio is absent.
Is there possibly a system setting or program setting that needs to be changed?
Thanks! ~Ken
heinz-oz
Post by heinz-oz »
Which audio format does your camcorder record in? What is your camcorders TV standard, also NTSC?
Maybe VS 9 does not have the required encoder?
Sheep Cloner
ram: 6GB
The TV standard is NSTC. I'm also having the same trouble with an analog audio/video signal. I recieve the video but not the audio.
Thanks! ~Ken
Aha, now as "number 5 alive" would say "We have more input!"
Try looking in your Windows control Panel at the audio settings for
Recording. You probably have the wrong input device selected.
View this link
Sheep Cloner
ram: 6GB
I've investigated that some. I was able to record analog audio and video with a separate piece of software. So I don't think the problem lies there.
I looked under recording settings and the only option I have is REALtek AC97 Audio. It does not allow me to select any other device. I think it may be an encoding problem. I have no idea how to correct it though.
Thanks! ~Ken
Have you tried ticking the other boxes shown in this picture?
Sheep Cloner
ram: 6GB
Yes Sir! I'm stumped.
Thanks! ~Ken
Jerry Jones
Post by Jerry Jones »
When you go through the steps of the tutorial, you should get to a point where the AUDIO PROPERTIES are precisely detailed by the Ulead software.
What are the properties of your AUDIO?
1. Does the software identify the audio as AC-3?
2. Or does the software identify the audio as LPCM?
3. Or does the software identify the audio as MPEG AUDIO?
Which?
Jerry Jones
http://www.jonesgroup.net
Gateway 7426gx
http://tinyurl.com/hagye
Sheep Cloner
ram: 6GB
It identifies the audio as Dolby Digital. Is that the problem?
Thanks! ~Ken
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Sat Feb 03, 2007 5:14 am, edited 1 time in total.
Do you have a full version of VS9 or one with SE after it? If you have the latter, then it does not come with an ability to handle Dolby audio (for licensing reasons since SE versions are free).
