Can't get correct usiudf.sys
JamesJames
Post by JamesJames »
Microsoft has identified usiudf.sys as what causes my PC to crash.
But the Ulead site will not let me download the correction.
I have PhotoImpact 8, Burn.Now, and CD and DVD PictureShow 3
I have registered all three.
PhotoImpact 8 is the full version, the other 2 came with DVD burner.
TIA
Jim
Ulead message
There are two possible situations you can’t pass the SN checking.
Incorrect Serial Number
The serial number you have entered is incorrect. Please check to make sure that your serial number is DVD MovieFactory 3.0 or DVD MovieFactory 3.5.
Unregistered Serial Number
You must be a registered Ulead user to take advantage of this. If you are not currently registered, please go here.
Microsoft message
Thank you for submitting an error report. The error was likely caused by:
Ulead Data-Add (usiudf.sys)
Ulead Data-Add (usiudf.sys) was created by Ulead Systems. Ulead Systems informed Microsoft that they have a solution available for the problem you reported. To learn more about the solution, Ulead Systems recommends that you visit the following website:
http://www.ulead.com/tech/general/data_add_country.htm
htchien
operating_system: Mac
Post by htchien »
Please contact Ulead Customer Service for your serial number problem. You will get faster response if you phone them.
Hope this helps.
H.T.
rlhart
Post by rlhart »
I am having the same problem with the ulead webpage. If I go to the link you added I can enter the serial number, but I get the error that I am not logged in. If I log in, I can find a link on the ulead tech page for the update patch.
