Picture on an object (sphere) ?
Hope someone can help me on this, I have tried searching but not found the answer.....
I have an object, e.g. a metal sphere and I want to have the image of a persons head on part of the sphere --- almost as if someone was being reflected in the metal surface.
As it's a sphere, i'd expect the image to be rounded like a fish eye effect and the colours almost blend into each other....
I'm a little lost where to start with this so would appreciate any pointers.
Thanks & Regards,
Brian
Thanks & Regards,
Brian
keenart
Ulead cannot accomplish the task you require. Ulead is a 2D program. You require a 3D program.
The closet you can come to accomplishing your task is to create a round 3D Path object and then use the Fill Tool to import an image as a texture and fill the Sphere. However, you will get the effect of an object inside a Globe rather than on the outside.
A 2D program has height and width, and appears to have depth, but actually does not, instead uses a gradient fill to emulate depth.
A 3D program has all three measurements called Cartesian coordinates the X, Y, and Z axis, or, width, depth, and height. With a 3D program, you can skin an image over an object and make it look as though it is being reflected on the outside.
3D programs are complicated and expensive. There is a free Open Source 3D program you might try called Inkscape.
rightasrain
heinz-oz
Ken provided information for our Free Stuff forum about Blender. It's a free 3D program, and quite powerful. However there is a steep learning curve. I've played around with it on and off for about a year or two.
http://phpbb.ulead.com.tw/EN/viewtopic. ... 9139#69139
keenart
I am in big trouble with all of the Virgos now!! I have been happily married to a Virgo for more than 40 years.
I have used the Open Source version of Inkscape, but have not tried Blender yet. How does it work with PI?
DAZ brought Eovia and Right Hemisphere is writting a new Editor for Microsoft called MS Expressions, I believe. Sounds like the old Metacreations Expressions. Microsoft's intrusion is making the whole industry a bit shakey. Xara is feeling the heat and so is now going to Open Source in hopes of surviving. Ulead is well enough situated, I do not think it has any worries. Hope Ulead will port to Linux.
I don't know how it works with PI, I uninstalled it before getting PI. (The on and off has been more off then on
) One of the most difficult aspects of Blender is it uses alot of non-traditional keystrokes.
Expressions that is now owned by Microsoft, was formally Creature House Expressions. I still have the beta version that M$ released. It is a super program.
keenart
fire--fly
reflection curving
http://www.karenskreations.co.uk/kkwaterreftut.html this tutorial is not one i had in mind but i think it will get u started
The water is ur globe and us lens distortion to get it to curve.
I will have time later to try to figure it out. I like puzzles
fire--fly
link to my result
https://ideastestingsite.com/image/Image2Jj.jpg
lets try to put in html maybe that will work
<img src="https://www.ideastestingsite.com/image/Image2Jj.jpg" align="left"/>
idk why not working gl
