Sound Delay
Flavius
Sound Delay
Post by Flavius »
Hello again...
I was having a problem when burning a dvd... well, i still have this problem, but now i am creating the DVD image file and burning in Nero.
The problem now is, when i do that, create the image file and burn in Nero, i watch the videos and each video i used Mult-trim, before the "cut" happens, i get the normal image, but the sound is not delay, its the oposite like 20 or 30 seconds jump to back (near where the cut would happen) then returns to normal and the sound repeat in the normal sequence of the video...
i dunno what to do now...
If i tri to burn direct with MovieFactory, it says the disc is not empty or device not ready, if i create the image file i get this crazy "delay"...
maddrummer3301
Post by maddrummer3301 »
Usually what most people do is burn a dvd folder on the harddrive
and test the video playing from the harddisk using PowerDvd or
WinDvd etc. Saves time and wasting dvd's.
You need to post the properties of the source videos.
How they were recorded along with all the properties.
It's important to post how the videos were recorded and what
settings were used to record the file.
It's also important to post the settings that MF3 says are the properties
of the file. They may not match because of different encoders which
will cause problems.
MD
Flavius
Post by Flavius »
The thing is... i created the same dvd without using Mult-trim...
(Note: i cut the beggining and the end of each video file and could burnt it withou any problem)
But when i use Mult-trim in the middle of the video file i get this sound problem...
(Note: i use in the middle of the video file because there is like a comercial on it, so i cut the begging, the and and the middle)
Other options are all the same, i havent chagne anything when using mult-trim in middle or not...
