1) Captured DV-AVI and edited. When viewing each clip I get a normal TV picture (covers full screen) but when viewing the project I get a nerrow and long picture, doesn't fit a TV screen (3:4). How can I change it?
2) When trying to burn a DVD, using DVD +R, I get a message that there is no disc or the disc is full, and can't go on burning? what seems to be the reason?
I'm a new VS8 user, facing 2 problems;
rcxue
Your problems
I am also new, and not sure about your problem #2.
On #1, I do recall seeing a selection in one dialogbox about support square pixels or non-square pixels. I think you may have this set wrong when rendering to mpeg. This may explain your raw DV project will view normal, but the dvd output is stretched.
Ray
Ray
vz00424
Thanks Ray
Thanks Ray
I overcame the second problem, but can't find the dialog box where to fix this "non square pixel".
I can see it in the manual pg. 151 but can't find it within the s/w
Moshe
Moshe
david reece
i have the same problem with a letter boxed mini Dv tape i did. if i capture with non sq pix renedering it gets squished.
if i uncheck this option it gets corected back to correct perspective for PAL.
I have taken this up with Ulead and it is being investigated.
My suggestion here is to use windows movie maker 2 to capture DV.AVi footage.
rcxue
IronMike778
Well, I followed all of your advice and think maybe I'm on to something from tweaking the Disk Template part of the "Create Disk" part. However, for the first time after burning about 20 discs the past week, I got this error: "Failed In Performing Power Calibration." What's this? And why am I just seeing it now after so many burns?
THoff
It could be a couple of different things, besides a software problem:
- * A weak power supply
* Incompatible media
* The drive is dying
