I have footage captured completely from my panasonic PV-GS200. Clips of pre-k kids lined up on stage singing. Side movement is very jittery just as field order issues would present themselves on TV playback.
I captured all the footage into Adobe Premiere and after trimming saved the compilation as a DV/AVI file.
I then brought it into DVD Workshop as I always do to menu. This time on playback (and ONLY on TV) the side to side pans I did of the kids and any real fast movement shows as very jittery. If played back full screen on my PC 21" crt through WMP all is crystal clear.
I tried two ways to encode in DVDWorkS. Variable bit rate 7500 and Constant bit rate 8200 LPCM audio. The only encoder in my list of available is the ULEAD MPEG Now Encoder. If you were to look at this you would say its a field order problem, but can it be using DV/AVI and then DWS ?
edit*** btw the speed ..... quality slide is all the way to quality
Am I missing something obvious here? This is a first. I always start my menuing with DV/AVI files. There is nothing else in this thing, very basic.
thanks,
dcp
