veditor.exe Entry Point Not Found please help
magnusg
Post by magnusg »
HI,
I am using MediaStudio Pro 8.0 full version. I downloaded the plugin Smart compositor with templates. Then restarted my computer as instructed. When I then tried to open MediaStudio Pro 8.0 I was unable, and I got the following error message. What to do?
veditor.exe - Entry Point Not Found
The procedure entry point ?ResetToEmptyRect@CScrollCability@@QAEXXZ could not be located in the dynamic link
library UIShareTolls.dll.
Thanks,
Magnus
lblack
Post by lblack »
Did you ever find a solution to this problem? I've just installed SP1 for MSP8 and now I get the exact same error..
Cheers,
Lars
superbabe
Post by superbabe »
same problem here! i have also just installed SP1 and get the same error message.
any suggestions welcome!!
cheers,
emily
htchien
operating_system: Mac
Post by htchien »
Make sure you have downloaded the correct SP1 from http://www.ulead.com/tech/msp/msp_ftp.htm
Some SP1 which is not from Ulead website is a beta patch and might lead to this issue.
H.T.
Ted (H.T.)
superbabe
Post by superbabe »
yes, that's exactly the on i've installed. ;( unfortunately, you can't uninstall it so i may have to reinstall the programme from scratch.
Devil
Post by Devil »
Which build number of MSP8 are you using (see Help|About - the 4-figure # gives the build #). SP1 will not install properly on builds <0030.
superbabe
Post by superbabe »
mh, unfortunately i'm no longer able to check the build number as the programme doesn't even start up. I get the error message straight away when i try to run it. :cry:
softlover
Post by softlover »
Devil wrote:Which build number of MSP8 are you using (see Help|About - the 4-figure # gives the build #). SP1 will not install properly on builds <0030.
I get the same error after SP1 installation although the build of UMS is 30. Moreover Ulead AudioEditor reports: : "A Key Error", Video Capture is unable to start due to problem with msUser.dll. HELP PLEASE!!!!!!!!
htchien
Post by htchien »
First, welcome to the forum.
The A-Key error means one of the following cases:
MSP 8 is not installed properly.
or
You are trying to hack (or crack) MSP 8 because A-Key is some codec protection mechanism in Ulead video / DVD products. You cannot start Audio Editor and Video Capture because the A-Key protection information is missing or is wrong. It has nothing to do with uvUser.dll (not msUser.dll).
Make sure you are using a legal version of MSP. Try the clean re-install procedure in the following link to see if it helps if you are indeed using a legal version:
http://phpbb.ulead.com.tw/EN/viewtopic. ... 5773#55773
If it does not help, you need to contact Ulead Tech Support.
Ulead Tech Support:
http://www.ulead.com/tech/techsupport.htm
superbabe wrote:mh, unfortunately i'm no longer able to check the build number as the programme doesn't even start up. I get the error message straight away when i try to run it. :cry:
If you still get your Ulead product installed in your system, you can use the following way to know the version build number of your Ulead product:
Select Start->Run in the Windows Task Bar to invoke the Run Command box and type RegEdit.exe then OK to start Registry Editor. Find the following folder in Registry Editor:
My Computer\HKEY_LOCAL_MACHINE\Software\Ulead Systems\<Ulead Product Name>\<Ulead Product Version>\Installer
In that folder you should see a ProductVersion value on the right panel.
H.T.
Ted (H.T.)
softlover
Post by softlover »
superbabe wrote:yes, that's exactly the on i've installed. ;( unfortunately, you can't uninstall it so i may have to reinstall the programme from scratch.
It doesn't require the reinstallation of UMS, you can use the XP feature: Programs-Accessories-System Tools-System Restore
softlover
Post by softlover »
softlover
Post by softlover »
