Burning problem to DVD from Ulead Videostudio
dee
I have sucessufully created an edited video using Ulead Videostudio 8 and placed it in My Documents/My Videos. I have tried to use the Ulead Create Disc facility and it gets to the point of actually burning the disc, but then I get the following error message: 'Failed to record data to the disc. ERROR DVDR-INC-SPTI-2A-02-03-0C-00. My DVD burner is HL-DT-STDVDRAM GSA and I was using a DVD-R 4.7 Gb disc. What am I doing wrong?
maddrummer3301
g-money
Cannot burn ISO image
Ulead VS10 allows me to create a DVD ISO image but I haven't been able to find a way to burn it. I have an older version 6 with DVD Factory that allowed me to do it but is there a way in the new version? Is the only way to create the DVD folders and then burn it? I had a problem when I chose Create Disk and tried to burn the DVD directly, it died.
Thanks,
G-$
Thanks,
G-$
Without more information about the file properties, project properties, work flow and computer resources you are using, it is impossible to suggest a reason. It could be because of a number of factors:
1) Incorrect (or not recommended) work flow -- going straight from a project in one format in the timeline to the burning stage (Share > Create Disc) without first producing a DVD-compatible file ( Share > Create Video File > DVD) -- read the Recommended Procedure in the first sticky post;
2) A packet writing software program such as Nero's InCD taking over your burning drive (uninstall InCD or disable other similar programs);
3) Something not DVD-compatible about a file or files you are seeking to burn;
4) Your burner does not like the brand of disc you are using;
5) selecting too high a burn speed (we suggest no more than 4x);
6) Possibility you have an SE version which is heavily crippled and does not allow burning of disc.
All that being said, I regularly only produce a DVD Video_TS folder of my projects, and burn them in Nero -- though I *can* use the VS10 burning module if I want and it works fine. It's just that I usually make a few copies of my 'masterpieces' for distribution to family and friends. It is easier to burn multiple copies this way (or by producing an ISO image file).
