Dear Forum,
I have a lovely small (50 seconds long) project that previews wonderfully.
The project properties are:
Microsoft AVI
24 bits, 800x600 pixels, 15 fps
frame-based
uncompressed
PCM, 44100 Hz, 16 bit stereo
When I hit
Share-->Create Video File-->Same as project settings
the program happily renders away until it hits 99% and then it crashes, without any warnings or messages.
Before you ask, yes, it *IS* necessary for me to save with exactly those settings in AVI format, so I am really stuck.
I have version 9.00.0100 of VS9. I found some updates on ULEAD's web site, but none of the bug descriptions seem to match this problem. I tried to install a patch anyway, but the "install shield wizard" claimed that I didn't have VS9 installed. Fascinating. Likewise, I didn't see anything like this problem on the forum - the advice there seems to be to save the project as a video file first to AVOID problems . . .
Can anybody help me?
Many thanks!
GW
VideoStudio 9 crashes when saving a .AVI file
gworthey
gworthey
gworthey
Other trivia: the first option after "same as project settings" is supposedly a 4:3 aspect ratio, but it also claims it is 720x480 (a 3:2 ratio). What gets saved on disk is actually a 640x480 file, which is indeed in the 4:3 aspect ratio, although if you look at the file's properties with Windows Explorer it will claim it is a 720x480 size. I am starting to think that this portion of VideoStudio 9 is riddled with bugs . . .
GW
GW
gworthey
Thanks for the idea, Steve J.
My video consists of two JPG images. In the "overlay" I then have 4 different video clips. I have some titles and a sound track.
To test your idea, I simply saved the project under a different name and deleted all of the video clips. Result: negative. It still crashes when I try to save an 800x600 AVI.
I'll try some other things along those lines. All ideas are welcome for this as-yet unsolved problem.
Thanks,
GW
Thanks,
GW
