Pixelation repair on DV frame
Goonie
I am editing some home footage that contains pixelation on a number of its frames. The way I wish to correct this without losing any frames is to open up the DV file so that I have a frame by frame view of the file. Then bring up one of the pixelated frames and note where on the frame the pixelation has occured, then go to a neighboring frame where there is no pixelation and copy and paste a portion of the good frame onto the pixelated area of the bad frame to repair it. Will MediaStudio allow or aid me in doing this?
Thanks,
Markus
Thanks,
Markus
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Hi Goonie, and welcome to the forums..
No, you can not copy and paste parts of a frame, using MSP. What version of MSP are you using? If you have MSP 7, Video Paint is included which would allow you to do something similar. If not then you would need to purchase Video Graphics Lab, Found Here, which is the old Video Paint and CG Infinity.
There are other third party applications that can do the same. What you are looking for is a rotoscoping program.
Goonie
skier-hughes
- Microsoft MVP
- ram: 4GB
I use Adobe premiere and photoshop, and in those you just do a frame grab and save it as a non-lossy format, like tiff, (Grab one bad and one good frame) and then open in photoshop and make the alterations.
Save as a tiff again.
Import the tiff into MSP.
Find the frame with the pixelation, cut either side of it, delete it, insert single repaired frame in it's place.
skier-hughes
- Microsoft MVP
- ram: 4GB
I suspect you may be using MSP7, which had a problem of random pixelating of frames.
If you have the full version, I suggest you install Service Pack 3 (free download) and recapture your DV. This will cure it - and give you a lot of other useful benefits.
The impression I got was that the source video is corrupted. As I understand it, MSP7 only had a problem with pixellated DV when the DV was being output, and then (IIRC) only on hyperthreaded machines.Devil wrote:I suspect you may be using MSP7, which had a problem of random pixelating of frames.
One thing the OP might try is to dump the whole source clip on the time line, then use "split by scene" specifying the frame content as the basis for the split. At least that way, the corrupted frames will all be split out as separate clips. and therefore easier to tab to.
Goonie
Thanks guys. To my understanding the footage is actually corrupt, due to a dodgy video camera. I have got the footage to a position of individual frames and been able to pinpoint the corrupt frames, but I cant work out how to edit them using previous and post uncorrupted frames. Yes I am using v7 and would be willing to upgrade to 8 if would aid in me fixing my footage.
Markus
Markus
Markus,
This is from Ulead's site under MSP7 FAQ:
Question:
I found some corrupted frames while rendering my video into DV type-1 AVI on my new Pentium 4 FSB 800 Hyper Threading machine. How do I resolve this problem?
Answer:
Please try the following steps to avoid this problem.
Install the latest MSP 7.01 update patch.
Download the .vio file (ftp.ulead.com/Silent/Uvavi.vio) and replace the original file into the folder below.
C:\Program Files\Ulead Systems\Ulead MediaStudio Pro 7.0\vio
Only do this if you have not applied SP2 or SP3 to original MSP7 installation. Both of these service packs include the improved uvavi.vio replacement.
Hope this helps.
Question:
Answer:
Hope this helps.
MSP8 won't help any more than MSP7.Goonie wrote:Thanks guys. To my understanding the footage is actually corrupt, due to a dodgy video camera. I have got the footage to a position of individual frames and been able to pinpoint the corrupt frames, but I cant work out how to edit them using previous and post uncorrupted frames. Yes I am using v7 and would be willing to upgrade to 8 if would aid in me fixing my footage.
You need a second copy of your AVI file. Note that a duplicate of the clip isn't enough - you need to have a copy of the file itself. Put the original clip on Va and the copy file clip on V1 or higher. Right-click the clip of this copy, and in "Media source options" make sure "Deinterlace" is checked.
Find your corrupted frame, zoom into it at 1-frame magnification, and scissor it fore and aft. Scissor the frame before it and the frame after it. You now have three single-frame clips - the one in the middle is corrupted. Move the preceding single-frame clip to the same timecode, but in the next highest track. Do the same for the following clip, but into an even higher track.
(So if your corrupt frame is on V1, the preceding frame is now at the same place but on V2, and the following frame is at the same place on V3.)
Do this for all your corrupted frames.
Select V1 by clicking on its name in the column on the far left. Press {Del} to get rid of the corrupt frames, and the stuff between the corruptions that won't be used in the repair (you need to delete this because it's deinterlaced). Select the first one-frame clip on V3 , right click it and choose "overlay options". Set the transparency to 50% (you'd normally need to do this at both the first and last keyframes, but this is a single-frame clip, so the first fram is the last frame).
Press {Ctrl-C} to copy the frame you've just amended into memory. Select the whole track V3 and right click somewhere in the resulting marquee. Select "Paste attributes" and OK the result (it will probably have "Media source options" and "Overlay options" checked - it's that letter you want to copy, but there won't by any nett effect by leaving the former checked, too.
That should do the trick... There are even more complex ways of doing it, such as having another copy so that you can specify a different field order to deinterlace, but that's when it starts getting complex.
Goonie
