Working Folder when creating disk - how can I change from C:
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
Post by jparnold »
How can the working folder (used on the last screen of create disk - ie the 'burn' screen) be changed from the C: drive?
I thought that I could change it in preferences (uder the General tab - Working folder) but I have that set to E:\TEMP yet in 'create disk' (last screen') it displays C:.
Unfortunately I don't have 4.6Gb free space (required to create the disk) and so want to use my E disk.
Videostudio v9
John
John a
lancecarr
motherboard: eMachines ET1861
ram: 12GB
Video Card: ATI Radeon HD 5400 Series
Hard_Drive_Capacity: 700GB
Post by lancecarr »
Yeah, sneaky that one isn't it?
The working folder under the genral tab is for the VS editor part of the program.
The burning module seems to be almost a standalone program. When you have the module open (Create Disc) click the icon next to the gearwheel down the bottom of the screen. There you will find yet another "working folder" setting. This one is diferent from the one you mention in your post. You can change it to wherever you want.
dave1006
Post by dave1006 »
In your 'burn' screen do you have an icon at the bottom of the screen next to the 'cog' icon? Select the preferences screen in that drop down and set your working folder to e:/temp and then your Directory will show E:/ .
Dave
jparnold
ram: 16GB DDR3
Post by jparnold »
Wow
I just went to delete this posting as in the meantime I worked out where the preferences are for create disk. When I di relist the posting I found that there were two replies already- thanks guys for the very prompt replies.
And as one of you mentiones - it is a "sneaky one".
I had NO problems working this out in VS8, so why did Ulead make this so difficult to find. Not very intuitive as far as I am concerned. I guess I should click on anything displayed just in case they happen to open a menu.
Anyway thanks again
John
John a
