I have made a further observation and would be keen to have this confirmed by others. Even if you do cut clips on I- frames there is another artefact introduced by using Videostudio to add transitions between clips and smart rendering the final output.
I first noticed this when using Sektionschef's test.mpg
If you cut on frame at 3:21 using VS or another MPEG editor such as VideoRedo (3:21 on test.mpg is an I-frame) and put a transition ( I used 1 sec fade to black) and then smart render using VS there is a movement artefact seen at 4:05 - 4:09. There are 5 frames at this point that are all the same and it comes across as a movment artefact when the clip is played. It is more noticeable in some players compared to others. And obviously less noticeable if there is minimal movement in the scene. I couldn't see the stumble in Virtualdub or VideoRedo but it was obvious in PowerDVD, WMP, Media Player Classic. The "still" frames were most obvious if you enlarge the preview screen on VS 11+ and step thru the frames one by one at 4:04 to 4:09. It is almost as if these extra frames are used as padding - perhaps to complete a GOP?
I tried this with HD MPEG2 from my Sony HC3 and confirmed that even cutting on I Frames doesn't allow VS smart render to produce transitions without the introduction of an artefact.
I examined the GOP structure of my HD MPEG2. There are 12 frames from I-frame to I-frame. Cutting on the B frame prior to the I-frame produced the distorted frames. Cutting on any other frames produced the segment of "still" frames". The segment of still frames varied from about 5 frames near the I-frame down to 2 frames away from the I-Frame.
I have yet to confirm that this movement artefact happens with all transitions and cuts when editing with VS, but all the single 22 cuts I produced at different times in the same 10 sec segment of HD MPEG from my Sony HC3 all had either the distorted frames ( if was cut on B frame immediately before the I frame) or "still" frames in all other cuts with smart render in VS 11+.
After using VS 11+ and smart render for the final composition I ran the video thru VideoReDo. Fortunately VideoRedo has a Quickstream Fix function which seems to remove these post transition "still frame" artefacts. (but videoredo was unable to remove the distorted frames artefact)
I know many have said that MPEG is not ideal for editing because of its GOP structure. VS's smart render is perhaps more appropriate for non mpeg editing.
Some individuals are forced to use MPEG to edit as this is the camera's or HDTV 's native mode. A complicated workflow is required with extra software if VS is used to edit MPEG2 video and add transitions with smart render involved in the final transcode..
Seems odd that this problem has not been documented before. Perhaps most peoples final MPEG2 --> MPEG2 transcode doesn't involve going from non rendered segments to rendered segments even with smart render turned on and thus the problem would not be observed?
smart-renderer produces shortdistortions with titles
Jerry Jones
On the other hand, it's difficult to see the problem unless you look carefully.
I would bet many individuals probably wrote faulty, smart-rendered MPEG-2 to a DVD and never realized it... until recently.
Personally, I've given up on smart MPEG rendering.
I doubt that the programmers currently employed by the various software companies have the necessary training/cleverness to get it right or they probably would have this issue fixed by now.
Womble is reportedly the only software that gets it right.
But Womble seems too basic in other ways.
So I just convert standard definition MPEG-2 to DV .avi for editing.
And I convert high definition MPEG-2/MPEG-4 to Cineform .avi for editing.
It works.
Jerry Jones
http://www.jonesgroup.net
It works.
Jerry Jones
ocular wrote:Seems odd that this problem has not been documented before.
Gateway 7426gx
http://tinyurl.com/hagye
Sektionschef
The new Sony Vergas Pro 8 seems to support long GOP HDV!
see http://www.sonycreativesoftware.com/pro ... PageID=107
under "Capture, Export, and Hardware Features" you can find:
"New! No-recompress rendering for long GOP HDV"
Unfortunately its about $700
Regards
Sektionschef
Regards
Sektionschef
Sektionschef
Hi Guys
Just an update because a new VS version and a update patch was released inbetween:
WARNING!!!
THIS TERRIBLE BUG STILL EXISTS IN VIDEOSTUDIO 11.5 INCLUDING THE LATEST UPDATE PATCH(Version 11.5.0157.2).
For me this sounds like:
-Ulead does not see this as an important bug although every DVD or HDD Camcorder user is affected!
-Ulead is unable to fix the bug because they do not get a fix from Mainconcept(maker of the buggy mpeg2 encoder).
Regards
Sektionschef
WARNING!!!
Regards
Sektionschef
Sektionschef
