Audio Trim/Edit Issue
cocoandmargo
Post by cocoandmargo »
This may be a stupid question, but can you enable audio when you are editing video in the time line or jog? As someone who has edited linear for 20 years, I edit clips by audio, more than video. Adobe Premiere has this capability--unfortunately that program has serious sync issues when editing MPEG 2. I'm using version 8
Post by BrianCee »
Not quite sure what your asking - if you mean should you be able to hear the audio when playing clips in the edit mode then the answer is yes - if you cannot you have something wrong somewhere - do you have volume turned up in UVS8 - what exactly are you doing.
If you are asking should you hear audio when you fast forward using the jog bar then no - it would be to fast and garbled any rate.
cocoandmargo
Thanks. I hear clips just fine in normal speed, but there's no sound when I'm trying to trim frame-by-frame or when moving the timeline. For example...how do you edit out several words in a clip??
DVDDoug
Moderator
Post by DVDDoug »
Do you want mute the audio without editing the video, right? Like mute or "bleep" the foul language?
Here's a summary of what I did:
- I used the share screen to create a wave file.
- I used an audio editor (Goldwave) to edit the audio... but I didn't make any edits that would change the length, or timeline-sync.
- I simply used the edited wave file as the soundtrack for my DVD.
Hmmm... Unfortunately, I've had the same problem with Video Studio! (...Looks like a bad
"lip-sync" problem... right?) I''ve been trying-out Womble Video Wizard. I haven't had the sync problem with it. Additionally, it seems to cross-fade the audio during a transition. Video Studio seems to hard-splice the audio at the end of the transition. I'll probably purchase the Womble editor soon... before the trial period is ends
cocoandmargo
DVDDoug wrote:Do you want mute the audio without editing the video, right? Like mute or "bleep" the foul language?
No, just want to be able to hear the audio as I shuttle thru the video--like at slow speeds to find a cut point in a speech. I guess it can't be done. :oops:
rwindeyer
Post by rwindeyer »
I think I know what you mean - like sliding a tape (or old-fashioned vinyl record) back and forwards quickly. The voices etc get to chipmunk quality but you would be able to tell where things started and stopped.
The bad news is that you can't do that in VS8 as far as I know. :(
Post by BrianCee »
but it is so easy just to cut a couple of frames and try it then cut again if not right and even put frames back again - I've never found it a problem not to have audio while doing fine editing
