Moviefactory5 Will not WORK
MarkJames
I have downloaded MF5 tonight, it installs fine and when i run the launcher i am presented with a Ulead Moviefactory 5 Menu, i choose Video Disk and New project but only the two editable disc programs work, creat a video disk does nothing except pop up a small box saying moviefactory with moving blocks then back to the menu again, please tell me what info you require to resolve this problem which is stopping the software from working.
heinz-oz
Have you actually imported any clips into the time line prior to wanting to create a video disk? At this stage I would hazard to guess that the problem sits in front of the PC.
No offence intended but how much do you know about the process of video creation? What is it exactly that you want to do? What are your source file properties and what do you want to convert to?
MarkJames
Thank you for your reply, I have been using Moviefactory for over 5 years now, I am a microsoft Certified Systems Engineer with an IT Background of over 18 Years, This is an installation problem, i have obviously made a mistake thinking this was a support forum, could any kind person please point me in the right direction for support on Moviefactory 5 from Ulead.
htchien
Since you said it might be a install problem, have you tried to re-install it again? See the suggested re-install steps in http://phpbb.ulead.com.tw/EN/viewtopic. ... 5773#55773
Please also list any video/audio codec packs you used in the system. Since you are an MCSE, it should be easy for you to find them.
I doubt some codec packs in your system might get conflicted with DVDMF. I remember Microsoft has listed some codec packs that will conflict with video programs in their tech support pages.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
MarkJames
I have uninstalled and reinstalled twice, i have removed all traces of the program inc the temp folders in my user directories.
Codecs as requested
Codecs as requested
Code: Select all
[Audio Codecs]
CODEC Manufacturer Description Status File Version Size Creation Date
c:\windows\system32\sirenacm.dll Microsoft Corp. MSN Messenger Audio Codec OK C:\WINDOWS\system32\SIRENACM.DLL 7.5.0324.0 116.00 KB (118,784 bytes) 24/01/2006 19:34
c:\windows\system32\mobilev.acm Not Available Hewlett Packard Mobile Voice OK C:\WINDOWS\system32\MOBILEV.ACM Not Available 56.08 KB (57,422 bytes) 15/10/2005 10:59
c:\windows\system32\l3codeca.acm Fraunhofer Institut Integrierte Schaltungen IIS Fraunhofer IIS MPEG Layer-3 Codec OK C:\WINDOWS\system32\L3CODECA.ACM 1, 9, 0, 0305 284.00 KB (290,816 bytes) 04/08/2004 13:00
c:\windows\system32\imaadp32.acm Microsoft Corporation OK C:\WINDOWS\system32\IMAADP32.ACM 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 16.00 KB (16,384 bytes) 04/08/2004 13:00
c:\windows\system32\vct3216.acm Voxware, Inc. Voxware Compression Toolkit OK C:\WINDOWS\system32\VCT3216.ACM 1.6.0.17 81.00 KB (82,944 bytes) 02/03/2001 19:46
c:\windows\system32\iac25_32.ax Intel Corporation Indeo® audio software OK C:\WINDOWS\system32\IAC25_32.AX 2.05.53 195.00 KB (199,680 bytes) 04/08/2004 13:00
c:\windows\system32\sl_anet.acm Sipro Lab Telecom Inc. Sipro Lab Telecom Audio Codec OK C:\WINDOWS\system32\SL_ANET.ACM 3.02 84.00 KB (86,016 bytes) 04/08/2004 13:00
c:\windows\system32\msaud32.acm Microsoft Corporation Windows Media Audio OK C:\WINDOWS\system32\MSAUD32.ACM 8.00.00.4487 288.00 KB (294,912 bytes) 04/08/2004 13:00
c:\windows\system32\msg723.acm Microsoft Corporation OK C:\WINDOWS\system32\MSG723.ACM 4.4.3400 116.00 KB (118,784 bytes) 15/10/2005 01:37
c:\windows\system32\tssoft32.acm DSP GROUP, INC. OK C:\WINDOWS\system32\TSSOFT32.ACM 1.01 8.00 KB (8,192 bytes) 04/08/2004 13:00
c:\windows\system32\lhacm.acm Microsoft Corporation lhacm.acm OK C:\WINDOWS\system32\LHACM.ACM 4.4.3385 33.27 KB (34,064 bytes) 01/02/2006 13:30
c:\windows\system32\msg711.acm Microsoft Corporation OK C:\WINDOWS\system32\MSG711.ACM 5.1.2600.0 (xpclient.010817-1148) 9.00 KB (9,216 bytes) 04/08/2004 13:00
c:\windows\system32\msadp32.acm Microsoft Corporation OK C:\WINDOWS\system32\MSADP32.ACM 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 14.50 KB (14,848 bytes) 04/08/2004 13:00
c:\windows\system32\msgsm32.acm Microsoft Corporation OK C:\WINDOWS\system32\MSGSM32.ACM 5.1.2600.0 (xpclient.010817-1148) 19.50 KB (19,968 bytes) 04/08/2004 13:00
Code: Select all
[Video Codecs]
c:\windows\system32\vp6vfw.dll On2.com OK C:\WINDOWS\system32\VP6VFW.DLL 6,0,6,4 432.00 KB (442,368 bytes) 06/11/2005 11:07
c:\windows\system32\ir50_32.dll Intel Corporation Indeo® video 5.10 OK C:\WINDOWS\system32\IR50_32.DLL R.5.10.15.2.55 737.50 KB (755,200 bytes) 04/08/2004 13:00
c:\windows\system32\msh261.drv Microsoft Corporation OK C:\WINDOWS\system32\MSH261.DRV 5.1.2600.2180 184.00 KB (188,416 bytes) 15/10/2005 01:37
c:\windows\system32\tsbyuv.dll Microsoft Corporation OK C:\WINDOWS\system32\TSBYUV.DLL 5.1.2600.0 (XPClient.010817-1148) 8.00 KB (8,192 bytes) 17/08/2001 23:36
c:\windows\system32\msyuv.dll Microsoft Corporation OK C:\WINDOWS\system32\MSYUV.DLL 5.3.2600.2180 (xpsp_sp2_rtm.040803-2158) 17.00 KB (17,408 bytes) 04/08/2004 01:56
c:\windows\system32\msvidc32.dll Microsoft Corporation OK C:\WINDOWS\system32\MSVIDC32.DLL 5.1.2600.0 (xpclient.010817-1148) 25.00 KB (25,600 bytes) 04/08/2004 13:00
c:\windows\system32\msrle32.dll Microsoft Corporation OK C:\WINDOWS\system32\MSRLE32.DLL 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 11.00 KB (11,264 bytes) 04/08/2004 13:00
c:\windows\system32\iccvid.dll Radius Inc. OK C:\WINDOWS\system32\ICCVID.DLL 1.10.0.11 78.50 KB (80,384 bytes) 04/08/2004 13:00
c:\windows\system32\msh263.drv Microsoft Corporation OK C:\WINDOWS\system32\MSH263.DRV 5.1.2600.2180 288.00 KB (294,912 bytes) 04/08/2004 01:56
c:\windows\system32\iyuv_32.dll Microsoft Corporation OK C:\WINDOWS\system32\IYUV_32.DLL 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 46.50 KB (47,616 bytes) 04/08/2004 01:56
c:\windows\system32\ir41_32.ax Intel Corporation OK C:\WINDOWS\system32\IR41_32.AX 4.51.16.03 828.50 KB (848,384 bytes) 04/08/2004 13:00
c:\windows\system32\ir32_32.dll Intel(R) Corporation OK C:\WINDOWS\system32\IR32_32.DLL Not Available 194.50 KB (199,168 bytes) 04/08/2004 13:00
htchien
Wow....
I think all Microsoft / Intel codec packs should be fine. I'm not sure about IIS MP3 codec. For others, I think you might need to check them.
Have you tried to rename the VCT3216.acm to other file name to try? I have some trouble with it before....
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
maddrummer3301
- ram: 2 GB
- sound_card: Intel GMA 950
Re: Moviefactory5 Will not WORK
MarkJames wrote:I have downloaded MF5 tonight, it installs fine and when i run the launcher i am presented with a Ulead Moviefactory 5 Menu, i choose Video Disk and New project but only the two editable disc programs work, creat a video disk does nothing except pop up a small box saying moviefactory with moving blocks then back to the menu again, please tell me what info you require to resolve this problem which is stopping the software from working.
Perhaps it is not an instllation problem but a fault with your video files.MarkJames wrote:Thank you for your reply, I have been using Moviefactory for over 5 years now, I am a microsoft Certified Systems Engineer with an IT Background of over 18 Years, This is an installation problem, i have obviously made a mistake thinking this was a support forum, could any kind person please point me in the right direction for support on Moviefactory 5 from Ulead.
Can we start off with the usual questions relating to the source of your video files, bit rates etc.
I do hope your not using MPEG4 DivX or Xvid.
As someone else mentioned this is a USER forum not the Ulead Tech Support Help Desk but we do our best to help.
maddrummer3301
- ram: 2 GB
If he cannot get the program to start at all then the first step is to re-install
using our suggested procedure
If that fails then it is a cse of looking for conflicting programs
OR
What is the source of the installation files - ESD download or on Disc.
Whichever - could be faulty.
OR
MarkJames
Thanks for that, i deleted both folders in mine and the All users dir and reinstalled, still will not load.maddrummer3301 wrote:Mark,
Do NOT Edit any of these configuration files.
Sometimes and rare I have to rename the MF5 under the user application data directory. This will force MF5 to retest some of the things on the system again and recreate the users configuration files.
MD
MarkJames
Done both of those and still not working, i think i will ask for a refund and use another product.sjj1805 wrote:If he cannot get the program to start at all then the first step is to re-install
OR
bigmalh
MarkJames
WOW, you sir are a God, it turned out to be Counterspy, i switch it off and it loaded fine, I thank you all for your help.bigmalh wrote:hi just a thought on your problem i seem to remember i had a similair problem after installing prog would hang turned out it was microsofts antispyware blocking certain files loading without telling me switched it off installed no problems since
bigmalh
