VS10+ Wont export to HDV, locked on DV
Ross
Post by Ross »
I have a Sony HDR-HC1E camera, and I'm having problems with video studio.
No matter what I do, it will only export in 720x540 resolution !!
I can capture at 1440x1080 resolution ok.
If I right click and select 'properties' it displays 1440x1080.
If I 'save as still image', the image is 1440x1080.
If I play the raw captured video it plays at 720x540
If I export the video as 'PAL MPEG2 HD ( 1440x1080,25 fps ) it still plays at 720x540 !! ( or any other setting for that matter.... )
When I play the video, it is in slow motion ( like it was captured at 29fps or something, despite everything being set to 'PAL 25fps' )
Please please help me, all I want to do is capture HD video from my HD camera. The only things that says the captured video is HD is Ulead, everything else thinks its only DV.
I have tried this with Proxy on and off, and every possible combination of capture / export. Just out of interest, if I capture using Premier Pro and then play the videos they are 1440x1080 and play at the right speed. I dont want to use Premier though as it really hogs up my machine and drops out a lot.
Any suggestions ? Why does Ulead insist my videos are 1440x1080 when they are only 720x540 ?
Any help appreciated, I'm pulling my hair out on this one.
lespurgeon
Post by lespurgeon »
Before you start, set project preferences to the right settings for HDV.
When you save ("share") try the same as first clip option - otherwise use custom. If you use a PAL DVD setting, you will only get PAL resolution as an option.
There is a tutorial by JC Hunter relating to
High Definition Tutorial Video Studio 10+
tyamada
Post by tyamada »
