maximum media clips
wai2hot
maximum media clips
Post by wai2hot »
on the trial version i tried to put 139 clips from home movies to dvd. it gave me a max. media clips is 99 error, is this true for full version also.
thecoalman
Post by thecoalman »
That's a DVD compliant limitation and is true for any software. You can't have more that 99 "titles" aka clips. You can edit some of them together if you want to insert more.
GeorgeW
I've seen different numbers...
Post by GeorgeW »
thecoalman wrote:That's a DVD compliant limitation and is true for any software. You can't have more that 99 "titles" aka clips. You can edit some of them together if you want to insert more.
I've seen different numbers for the max number of titles per dvd. Some say 99 across the whole dvd, and I've seen 99 per VTS, with max of 99 VTS's.
With Ulead software, the max is 99 (you can combine several into one title to get around that).
Even in DVD WS where it supports multiple VTS's, it still has a 99 title limit, so not sure which number is correct...
dvd-replica.com has the following:
The DVD specifications allow a maximum of 99 titles per video title set. Since there is a limit of 99 VTSes per DVD disc, the maximum number of titles per disc is less than 10,000 titles. For practical purposes, most authoring packages limit the number of titles to 256 or less.
George
