Capture stuttering/dropped frames
Can anyone advise please what to do next? MSP8 reports 2-3% dropped frames during capture despite taking every precaution (that I can think of) to prevent this problem. Even WinDV drops frames, is there something I've failed to do?
Thanks in advance, Simon.
Here's my set-up...
Capturing to a laptop (single hard-drive only): -
MediaStudio Pro 8
Win XP Pro Service Pack 2
Pentium 4 @ 2.4 Ghz
1 GB RAM
Anti-virus disabled, unnecessary background tasks suspended, system tweaks applied (i.e. DMA on, disk has been defragged, Disk indexing OFF).
Camcorder, Sony DCR-PC9E connected thro' firewire.
Capture set-up: -
720 x 576 PAL, DV type-1 (even tried type-2)
Device control: MS1394
Plug-In: Ulead Direct Show
Here's my set-up...
MediaStudio Pro 8
Pentium 4 @ 2.4 Ghz
1 GB RAM
Capture set-up: -
It is hairy when you do everything on a single HDD and when it is a laptop HDD, it is even hairier. My first advice is to clean off everything that you never use and then thoughly defrag the disk and I don't mean run the Windows legacy Intel defragger, which is an abomination unto mankind. Use a real defragger, such as Diskeeper.
Sisoft Sandra has an excellent disk speed measuring system and general performance diagnostics. The free version is excellent value for money!fatbloke wrote:No conflicts, capturing to the laptop hard drive. Can't seem to find diskspeed32 despite a search. Is this part of XP or a utility I can download?
heinz-oz
heinz-oz
One of the lessons being: If you can avoid it, don't use a laptop. Laptop HDD are generally slow rpm drives. You may get away with it if everything else is streamlined. HDD's on a desktop are predominantly 7200 rpm drives with a faster interface than the 5600 rpm ones fitted to a laptop. In both cases UDMA should be enabled.
