define default project properties
Sektionschef
Post by Sektionschef »
Dear all
Is there a way in VS10 to save the project properties as default project properties so that every time VS10 is started it comes up with these settings?
Regards
Sektionschef
Post by Trevor Andrew »
Not as far as I know.
But you could create your own project template using the properties that you need.
When you start a new project open the template, then ‘save as’ will preserve the blank template to use again.
You can change the aspect ratio by default from 4:3 to 16:9 via the start up screen.
Trevor
Sektionschef
Thanks for your answer.
Regards
Sektionschef
