Photo Express 4.0 Unable to open program
Mikeulead
Post by Mikeulead »
I have had PE 4.0 on my computer for 2 years working OK. Yesterday I noticed when I clicked on the startup ICON on my desktop it failed to open.
I went to the Program Files ULEAD folder and clicked on the execuatable from there and it would still not open.
I removed the program from control panel add/remove. Than I reloaded the program from the install CD. Still not able to start the program.
Read through this forumn for similar problems. One answer maybe to remove the K-Lite Codex pack. Where is it or how is that done?
Any other Ideas of what may have happened
Mike
herbyheroe
nearly same prob
Post by herbyheroe »
I´ve nearly the same problem, but I just installed PhotoExpress 4.0.
It didn´t work (there is running a process ipe4, but no programm is running)
I use WinXP professional SP2.
I tried the programm under Win98 and it worked.
I removed and installed it again under winxp and again it didn´t work... :x
Mikeulead
Post by Mikeulead »
In reading about CODEXs on the web it indicated that they were used in conjunction with photo /movie viewers. While I was still unable to locate the one mentioned in my first post I recalled that I had downloaded a viewer earlier in the month.
I had reloaded PE 4.0 and while it is present on my system I was still not able to open the program.
I went into Control Program and removed the movie viewer I loaded earlier to view DIVX files. Without reloading PE 4.0, the program imediately began to run when I clicked on the ICON.
My problem is resolved
herbyheroe
that is good for you, but not helpful for me... :cry:
lighty
Post by lighty »
herbyheroe wrote:that is good for you, but not helpful for me... :cry:
I have a similar problem but whenever i tried to open PE 4.0,and after i selected an image that i want to use of,I will get a message saying
"Ulead photo express has encountered a problem and needs to close.We are sorry for the inconvenience"
Can anyone help me pls...I did everything already including uninstall and reinstall the program but the result that i gained is still the same :cry:
lazael
Post by lazael »
I had DWS MF5 and PE freeze on start-up. Re-installed to no avail. About the reformat when I found 'DirectX stopped' when checking the System Configuration Utility. Searched for directx and found a suspicious looking file named 'dirextx.exe'. Renamed the extension and rebooted - all ok :wink: .
I think it's one of those scam virus / worms that companies infect you with and then offer to fix at a price.
Wonder why my malwal proggie Ad-Aware SE Personal did not find it ( ok my update was 484 days old ) :oops: .
"directx.exe - Here is the scoop on Blaxe / Logpole Worms as it pertains to computer network security. The big question: what is directx.exe and is it spyware, a trojan and if so, how do I get rid of Blaxe / Logpole Worms?"
htchien
operating_system: Mac
Post by htchien »
DirectX.exe does not belong to any Ulead products. I suspect that you've got virus infected in your system to cause the issue.
Hope it's not the case but it looks like a virus.
H.T.
Ted (H.T.)
VidManLarry
A fix for the same problem! PhotoExpress 4.0 SE
Post by VidManLarry »
Hi. I can't quite remember where I found this fix... after a massive Google search, I think I finally found the fix somewhere on this message board.
That being said, I apologize if this is a duplicate posting... so back to the fix!
Either a microsoft patch, or DivX, or both affect the "VIO" folder.
If you browse through Program Files/Ulead Systems/Ulead Photo Express 4.0 SE, you should find the VIO folder.
Inside the folder is a file called uvavi.vio.
Create a new folder and drag the item into the folder.
This way, if the fix doesn't work for you, you can just drag the file back to where it used to be.
Launch PhotoExpress 4.0! It's worked for me for 3 different PC's!
Good Luck!
katman_pimmie
Re: Photo Express 4.0 Unable to open program
Post by katman_pimmie »
Mikeulead wrote:In reading about CODEXs on the web it indicated that they were used in conjunction with photo /movie viewers. While I was still unable to locate the one mentioned in my first post I recalled that I had downloaded a viewer earlier in the month.
yup, it worked for me too
cahalanl
Post by cahalanl »
This was identical to what I encountered today. After reading this, I realized that I recently downloaded and installed the Cole2kMedia Codec Pak. I had already uninstalled and reinstalled PE 4.0 with no joy.
Using the Add/Remove Program of Windows in the Control Panel, I was able to uninstall the codec pak. Now PE 4.0 is back to working fine. It is obvious that PE 4.0 does not play well with these codec paks.
serf
Post by serf »
I use PE 4 also and it would not open after I installed DivX codec. After uninstalling the codec PE 4 opened again
htchien
Post by htchien »
I think PhotoExpress 4 might not be DivX compatible and you might need to upgrade to PhotoExpress 6 to fix it.
http://www.ulead.com/store/pe/runme.htm
Sorry if I did not help much....
H.T.
Ted (H.T.)
patthepiper
Photo Express 4 - unable to start
Post by patthepiper »
I have had to reinstall PE4 and my scanner software. I now cannot get PE4 to start. I have tried Remove and Reinstall but still have the problem.
Regretfully I hadn't registered the software, and in trying to do so the Serial Number I had recorded was not accepted, so I cannot get technical help.
I'm running XPPRO SP2
bombenjaeger
Post by bombenjaeger »
Hallo ulead team
i come von germanny me english ist not good
I have the problem ipe4 trial the prog is not aviabel mit winxp sp2 i be admin for my pc prosses start for 4sec dont not open your prog ip4
germann write
Hallo ulead team
ich habe ein problem das ipe40 trial hab ich installiert aber es ist nicht aviabel mit win xp sp2 bin admin von mein pc trotsdem geht das prog. nicht auf der prosses l酳ft etwa 4sec aber es 鐪fnet sich nicht.das IPe40
ist das beste was ihr je gemacht habt weil mann mehrbearbeiten kann die fotos als wie mit express 6 wen ihr so ein prog nochmal so hinbekommen k霵ntet wie der express 4 nur das es auch vabiabel ist mit xp das wer super hab auch die orginale cd von ipe40 die funktioniert auch nicht
gruss benny
