Computer freezing at 99% rendered
Larry Dickman.
Post by Larry Dickman. »
Hi lancecarr, I have about 40 gig free.....
I will try your suggestions, but to me, it seems that it is something to do with VS 10, as I have been using VS 9 in the exact same way for about 18 months, with no probs.
lancecarr
motherboard: eMachines ET1861
ram: 12GB
Video Card: ATI Radeon HD 5400 Series
Hard_Drive_Capacity: 700GB
Post by lancecarr »
You could very well be right there, I was just reading the thread and figured why not throw the kitchen sink in as well seeing how you Ken and Terry had given it a good chew.
Reading the suggestions already given, couple of things to try to confirm/disprove these suggestions as posible causes.
1. Overheating. Remove the Computers case to allow more air to circulate, also check the fans for clogging up and see if they are spinning OK.
2. Regarding turning off unecessary processes please view this post:
Create a Video Editing Profile
If these steps do not cure the problem at least we have eliminated these as causes and can start looking elsewhere.
Larry Dickman.
Thank you all........I shall return!
welchb
Post by welchb »
You've probably already had more expert help than this suggestion but I think worth adding anyway.....
Do a few simple tests, for example --
1) Load a really smally AVI clip (1min or so) and render this
2) Do the same thing with a couple of different formats, if possible
Do not have any transitions/overlays'/audio....
If 1) and 2) do work, then add in transitions/overlays/audio in steps and repeat the process of rendering....
It's not science and will take a little time but may help to pin-point wha's causing your issues.
All the best,
Brian
Larry Dickman.
Thanks Brian..... I am just going through the "create profile' thing, but I will give your suggestion a go....
Steve, as mentioned, I am creating a video editing profile....when I try to edit the start up menu/registry, it appears that the start up folder is empty?? Is this normal?
Also, now I have a new profile, I have lost all my video clips/projects when I open VS10+ in my new account........
If you've done the video editing profile correctly then the startup menu
and registry run sections will be empty unless you have deliberately kept something there.
The 'missing' video clips/projects aren't missing they are in your normal user account.
I'm at work now but from memory its something like
c:\Documents and Settings\username\Application Data\Ulead Systems\VideoStudio\<Product Version>
Think of it this way.... without a video editing profile but with each member of your family having their own XP user account.
Each member of your family can have their own desktop with their own desktop wallpaper, shortcut icons etc.
It's the same with the programs used by your family members.
If 'Fred' opens Microsoft WORD it lists Freds credentials and a list of Freds most recently opened documents. Now if 'Jean' does the same you get Jeans credentials and a list of her most recently opened documents.
Same goes for VideoStudio.
I thought I'd jump in here to just add, that I finally got busy (off my lazy...) and done the complete Video Editing Profile per your (Steve) tutorial. I must say there is a difference. My processes dropped from 31 running to 19..
Thanks Steve..:)
Larry Dickman.
Thanks Steve...all understood, found the "missing" files. :)
About to try and render again..............
I concur with Ron P. the seperate profile tutorial is well worth the effort.
Here I go again.....won't be till tomorrow though, getting a bit weary.
Thank you all.
Larry Dickman.
Well the plot thickens.... I have good news, and bad.....the good news is that I have created a video file of my project.... Creating a new 'video editing' profile worked a treat............thanks Steve!
The bad news is that when I try to create a disc (yes, I have started a new project with noting in the timeline, and settings exactly the same as my video file, I get the 'project will take some time to render' message.... I have gone back and double checked my settings to no avail....VS 9 is looking better each day........
PS. Properties are:
NTSC DVD
Mpeg 2, Lower field first
Data rate: 7456 kbps
Dolby Digital audio/ 256kbps
Larry Dickman.
One other question.....the video files I am using have a Dolby Digital (256kbps)soundtrack, which I have muted about 70% of, and overlayed a PCM audio track......when I create a video file, should I set the Audio format to Dolby Digital or LPCM?
LPCM is to audio what uncompressed AVI is to Video - large in file size and best quality. Dolby can now be considered universal and is a much smaller file size. It is so well reknown that I do not have to comment upon its quality.
The smaller audio file size (Dolby) means that there is more space on the DVD for either - more video, or higher quality video.
PeterK2
Post by PeterK2 »
After having no problems at all with VS9, including doing some of the things members recommend against, I encountered exactly this problem with a 35 minute render with VS10+.
I was using some of the new filters in VS10 and thought that might be the problem. However rather than go back and change them all I cut the video in half as suggested earlier in this post. Both halves rendered OK with no problems.
I will also try the editing profile suggested earlier and see how that goes. I don't normally have any problems except that if I do a lot of editing in one go, ie 2-3 hours on the PC, it starts to crash. Restarting VS usually fixes this.
Peter
davidhaynes
motherboard: Gigabyte 8I945GMF
processor: Intel Core i7 9700F CPU 3GHz 3GH
ram: 32gb
Video Card: NVIDIA GeForce GTX 1650
sound_card: Onboard 51
Hard_Drive_Capacity: 500 gb
Monitor/Display Make & Model: 2 X Samsung S27F350
Corel programs: VideoStudio 2019, 2020, 2021 CorelPaint
Post by davidhaynes »
I am having the exact same problem and I can only put it down to the fact that I am using up to 40 different transitions throughout the project.
I did a similar project but used the same single transition all the way through - this project rendered perfectly and very quickly as all files were mpg files.
The project that is freezing uses all different transitions and I am starting to think that VideoStudio doesn't like some of them!
The new high end PC that I am using is brand new and only has Windows XP Pro SP2 and Video Studio 10 + installed on it!
To get a finished product I have had to divide the project into 3 separate mpg files and then combine them as mpg files at the Create Disk stage.
Larry Dickman.
Pretty ordinary if you ask me.......I expected more, after having so much sucess with VS 9.....guess my choice is easy, and will save me a few bucks.
