HOW TO CREATE MENU??
Locked
dude16
Post by dude16 »
How do I make a menu, with 2 chapters for a FIFA game, I want small clip running in the background for the menu. How do I do this? I want to show the goals scored in a different chapter , just the goals scored, how would i do this, but including the full game, (2 chapters) and then the highlights of the goals being scored (1 chapter)
maddrummer3301
Post by maddrummer3301 »
You also posted about capturing TV.
That depends if MF5 is compatible with your capture device.
I can capture using MF5 TV/s-video/composite signals.
Hard to answer your question. Not sure of exactly what your trying to do.
You have to create chapters in the video under "Add/Edit" Chapters.
Then those chapters will showup in the menu creation stage.
If you want to make a separate videos on the menu page of the highlights of the game use the EXPORT feature.
While on the timeline mark the IN and OUT of the parts you want to extract.
Then goto EXPORT -> Fast Export and save the new file.
After you do that RESET the original video back to normal so the original complete video will play on the dvd.
Then IMPORT the video you created in the EXPORT screen previously.
You can do that many times.
Also clicking on the GEAR icon at the bottom of the page tell the program how you want the dvd played back.
MD
dude16
Post by dude16 »
So do I get the original video file, plus addidtional of it using the export button, and transferring it. Where do i import the export clip too? Do i count it as a chapter?
Locked
