Application Error Photoimpact 10
zsuzsa
Post by zsuzsa »
I had installed and used Photoimpact 10 in this computer more than a year now. Yestarday I had to use ctrl+alt+del because it froze. Since than whenever I try to open it and the main window is loading I got this message:
"Application Error Faulting application iedit.exe, version 10.0.0.0, faulting module xulparser.dll, version 10.0.0.0, fault address 0x0005c518.
I run Registry mechanic, PC Speed registry correction, Uninstalled reinstalled, and still got the message I cant open PhotoImpact. What happened? Can anyone tell me?
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
Try to find in you user profile file named Current.xum. Rename it. Now try to start PI.
X.
zsuzsa
Post by zsuzsa »
Thanks for responding.
How you do that? What exactly I am looking for ?
To find the file Current.xum go to your Search in Windows (Start>Search), then search your current profile (C:/Documents and Settings/Your User Name) for that file. It should show up under Ulead Systems/Photo Impact Folder..
Then when you find it, right-click it, and choose Rename. Rename it to something like Current.old. Then restart PI...
zsuzsa
Post by zsuzsa »
Thaks Ron
After deleting everything I couldn't find any Current.xum file. I disabled my Norton Internet Security and installed PI 10 again. It worked! I was so happy! Not for so long.. when I closed it and unabled Norton open PI 10 again it froze. Shut down computer and started PH10 with Norton disabled. It works. In the browse window I fund a foldet Ulead.dat and I deleted it. I am not sure this was the one I had to delete or not but after that everything is worked so far with Norton running also. I cross my fingers.
I do not understand something : I also run registry mechanic and found after the PH10 instalation 50 something error including lots of font errors.
I wrote this here maybe one of you could make something out of this. I can't.
Thanks again, hope it will work.
