it is said here that
http://www.ulead.com/vs/new.htm
JVC® hard drive camcorder MOD file format is supported.
my question is:
has anyone tried this?
does it work straight forword or it needs a plug in?
thanks
Re: JVC® hard drive camcorder MOD file format
If it doesn't work, there is a very easy solution:hamohd70 wrote:it is said here that
my question is:
thanks
rename the .mod files to .mpg, and they will work with any program that reads MPEG-2 files, including Ulead programs.
lancecarr
- ram: 12GB
- Hard_Drive_Capacity: 700GB
JVC .MOD
The JVC camcorder uses standard MPEG 2 encoding with AC3 2 channel audio. My daugther has one. Who knows why they chose the .MOD extension.
Phenom X4 965 3.4Ghz, 8gig DDR3, 120GB SSD, 1TB HD, 500GB, Bluray & DVD Burners, ATI HD5550, Epson scanner, Canon 9000Pro, Sharp AL1551CS laser printer, Sony TRV740 8mm digital, Canon HV20 and Sony SLTA65VK, Win7 HP 64bit
Gary Russell
TNUSA
Gary Russell
TNUSA
lancecarr
- ram: 12GB
hamohd70
i downloaded a trial version of vs10 to try it with the JVC mod files and found that it isi possible to import the mod file directly into the library or through the capture page -> import from mobile devices.
i then tried to make a movie file (mpeg2) , it went fine with no problems.
so there will be no need to change the ext. to mpeg for it to work.
thank you all.
thank you all.
