Pex.exe Error Box
Eryk
Pex.exe Error Box
I can't use Photo explorer 8 SE basic, Cuz evertime I open it, it has a program error.. sayin'.. "Pex.exe has generated errors and will be closin' windows. an error log is being created" I tried to "repair it".... Help?
wleague
ermel
htchien
Go to the following folder:
[PEX install folder]\VIO
and rename the uvAVI.vio file to uvAVI.bak then start PEX to try.
However, it will disable the AVI playing capability of PEX. If you double clicks on an AVI file in PEX, it will use the default player in Windows to play the video.
If this works, then some audio / video codec packs in the system is conflicted with uvAVI.vio and you need to disable the codec pack to make PEX work with the AVI playback capability.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
