keeps crashing whilst adding text, WHY???
ali4life
please could someone stop me from going mad!! i am doing a project for school and have been told to design a sports day poster using photoimpact. now i have set it up but it keeps crashing, like mad. when i go to the EasyPalette - Image on the right hand side, i select Libraries, then Text, then Compostion and then CO4. when i try to edit the text it just crashes and the windows error message appears. i have tried doing it again but again the same thing. now i have to finish the project but this flipping thing has decided it wants to ruin me. please could someone help me. any help greatly appreciated. thank you
heinz-oz
It could be a memory problem, physical as well as virtual.
Since we do not know what your system spec's are or even which version of PI you are using, it is impossible to be more specific.
What is your OS, how much RAM, how many HDD's, size, free space, when defragged last, wher does your swap file reside, where are the PI temp files located, have you limited the use of memory and disc space for PI? etc.
emmade
mculver
Also Having Problems
I am able to reproduce this text behavior 100% of the time. Running XP SP 2 with all the latest updates.
keenart
I have all of the Win XP SP2 updates and PI11 with patches, but cannot reporduce the problem.
ali4life
Are you using a True Color Image, nothing less will work? Did you uncheck the Disable Object Pick Mode while Drawing, on the Tool Settings?
When I do the same, with the Text Tool highlighted and before I Edit the Text, I right click on the Text to reveal a menu, and from that menu select Edit Text. The Cursor moves to the beginning of the Text and I can retype new text.
The other method of changing Text is to run the Cursor over the Selected and Highlighted Text, which means the marching ants moving around the text, until the little T shows up in the center of the Cursor. When this occurs, double click on the Text with the T Cursor and you can retype new text. This method is good for correcting individual letters.
ali4life
mculver
How to repro
On my system I simply start Iedit, create an empty image (16 color or truecolor), click on the text button in the left-hand toolbar, then click anywhere on the drawing surface. Throws a memory exception right away.
The reported error is "Unhandled exception at 0x016d2560 in Iedit_.exe: 0xC0000005: Access violation."
I (obviously) don't have access to debug symbols because I have the retail version of this product; however the stack trace is below. It dies on the POP.
016D254B add byte ptr [ecx],dl
016D254D add byte ptr [eax],al
016D254F add byte ptr [eax],dh
016D2551 add ebp,dword ptr [ebp+1]
016D2554 je 016D25A3
016D2556 aas
016D2557 add byte ptr [ecx],dl
016D2559 add byte ptr [eax],al
016D255B add byte ptr [ecx],ah
016D255D add byte ptr [eax],al
016D255F db 00h
016D2560 pop eax
016D2561 push 16D23F0h
016D2566 push eax
016D2567 jmp dword ptr ds:[16D2570h]
016D256D add byte ptr [esi+1],ch
016D2570 rcl byte ptr [esp],60h
016D2556 aas
016D255F db 00h
016D2560 pop eax
016D2566 push eax
keenart
mculver
If clearing out your Temp folder does not do the trick, then I would say you have a bad install. Somehow the Registry keys are corrupt. Perhaps the anti-virus did a number on your install.
If that is the case uninstalling, deleting the two Ulead Folders and reinstalling with the anti-virus turned off is the only option left.
mculver
Reinstall Does Not Help
I uninstalled Ulead, as well as all the ancilliary things that came with it. Then I deleted all temp files under "Documents and Settings", as well as files that were left in the "Program Files\Ulead" tree.
Reinstalled just Photoimpact 11 with no patches, no other Ulead goodies of any sort.
Created a new blank file, selected the text tool, then clicked on the drawing surface. Instant application exception....
keenart
mculver
Microsoft says:
Unhandled Exception Error.
Unable to run Application.
1. Disable the initial Splash screen.
2. Problem: When user clicks on the Application icon to run program, program starts to come up then freezes while loading *d.dll (may also occur shortly thereafter)
3. Resolution: this is the conflict involving your video card, if you go to start/control panels/display then find the setting called hardware acceleration turned that down to none and retry this should allow the Application to run. Most common with users who have Nvidia graphics cards.
4. If the previous does not work then you may have to uninstall your graphics cards drivers and reinstall the correct version. You will also have to reinstall the morst current version of Direct X.
Microsoft says:
mculver
Sounds like this answer is for some other problem. I am able to start the app just fine, and in fact PhotoImpact 11 works just fine for anything other than adding text.
Nonetheless I turned off hardware acceleration in the DirectX applet inside control panel. Same issue remains: when I click on the image after selecting the text tool, the application throws an exception and dies.
keenart
robperez
one solution
I was having the same problem - any attempt to enter text killed PI11. I disabled DEP for photo impact and things seemed to get better:
1. My Computer - Properties
2. System Properties. Advanced tab.
3. Performance - Settings button.
4. Performance Options, Data Execution Prevention tab.
5. Second radio button (on for all but what I select).
6. Select PhotoImpact (if this is what the problem was, it should already be on your list, otherwise, you can locate it by browsing).
Hope this helps.
Rob
Hope this helps.
Rob
keenart
Thanks It Works!
Here is more info on DEP from Microsoft:
http://www.microsoft.com/technet/securi ... cnfxp.mspx
