when i capture HDV video from my Sony HC3 it works perfectly.
Then when I open the .mpg file in Video Editor and rerender it to hdv .mpg (Programm Stream) it also works perfectly. It takes just a few seconds and I think that´s native without recompression.
BUT when I open an .mpg HDV file and render it as .m2t (Transportstream) it takes 4 times the video length. It renders frame by frame and I don´t think that´s smartrendering. It seems the video is recompressed and that is what I want to prevent.
What setting do I have to set that Medistudio smartrenders the programm stream into a transport stream?
Or is it usual, that it takes almost two minutes to render an .m2t file out of a HDV .mpg file with the length of 30 seconds?
My Hardware:
AMD Athlon 64 3200+
1 GB Memory
IDE Harddisc
Geforce 6800GT
BTW: Sorry, for my poor English. I´m from Germany.
Serious problems with HDV Smartrendering
PredatorGER
I haven't lost quality, but MSP8 doesn't capture natively, if it did you would get a .m2t capture file. If you have software that captures in .m2t format MSP8 will not edit the file, it has to be converted to .mpg(strip out the transport stream packets).
If you have a computer that has a processer 3.0GH or above trun off proxy support, it takes longer to create the proxy file than to edit and create a HD file.
PredatorGER
