AMD dual core or Intel Pentium 4 hyper thread + Videostudio
astor
Hi all,
Does anyone has experience in terms of stability and speed with
Videostudion 9 and dual core or hyper thread CPUs.
Is there any advantage with this product at all using new CPUs ?
Have fun
Ralph
Have fun
Ralph
Within any version of Video Studio I'd be surprised if there was any real difference between using a dual core processor and a hyper threading processor. I use a P4 3.0 hyperthreading processor in VS10, and, given the functionality of Video Studio, I can't imagine how a dual core processor would perform better. Maybe someone on the forum has used both types of processor in the same version of VS and can inform us accordingly.
Terry
THoff
Hyperthreading helps, and a real second core is even better. But don't expect the differences to be dramatic:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=14202
I should note that if you encode to WMV, a second processor (logical or physical) seems to get utilized fully. I haven't done benchmarks, but Task Manager indicates that the second processor is completely busy.
THoff
maddrummer3301
THoff
Or, for a comparison, you can deprive Videostudio of the second processor.
Open up Task Manager, go to the Processes tab, find VSTUDIO.EXE, right-click on it, and select the Set Affinity option. Leave only CPU 0 checked, and Videostudio will only be allowed the first processor.
If you have a system with Hyperthreading, the physical processor is CPU 0, and the logical processor is CPU 1.
With a dual-core processor, the two cores are obviously CPU 0 and CPU 1.
With a dual-core, Hyperthreading-enabled processor, the two physical cores come first, and CPU 2 and CPU 3 are the logical processors. This allows applications that are trying to take advantage of a basic Hyperthreading processor to talk to the physical cores instead, which should result in better performance.
Sal M
Twice Realtime Transcoding
I built the overclocked Pentium D 805 in Tom's Hardware (http://www.tomshardware.com/2006/05/10/ ... ghz_cores/) and am currently running at 3.8 Ghz. My entire system cost $1,100 and I can render 1 hour of MiniDV AVI into 8000Kbs, 29.97fps, 100% quality with MPEG audio 256Kbs, 4:3, single-pass in 30 minutes. I normally don't overclock, but Intel shifted production to the B0 series which can handle 3.2Ghz easily. If I had supercooling, I'd go to 4.1Ghz as they did in the article.
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
maddrummer3301
THoff
MD, that's not how it works.
Changing the PAM (Processor Affinity Mask) only controls which processor(s) the Windows scheduler will allow a process to execute on -- it will not let you run more than one instance of Videostudio. The procedure I described should be used only for comparing multi-processor performance on an otherwise identical system.
lespurgeon
J_fike
I use a lot of 3D graphics programs on a dual core AMD 4800. Some support multi-threading and some don't. With a non-multi-threaded application like Bryce, I can run two instances of Bryce and plop render half of the same scene with each, and thereby approach 2x in render speed.
Carrara 5 supports multi-threading so it will render nearly twice as fast on a dual core machine.
Your graphics card and the amount of system memory will also determine how efficient your computer will be with dual cores. So playing a highly graphics intense game and doing a video edit (you probably wouldn't be doing that anyway) wouldn't work too well. But you could run an Excel spreadsheet and do a single core render and probably never notice a slowdown.
As maddrummer3301 said, one advantage of a dual core machine is you can do a normal render while working in another application without very much processor penalty at all.
shoalhaven
Dual Core
Maddrummer3301, thanks for your info.
Do I read you right, should I be able to do a normal render and work on Word Processing at the same time?
By the way, I have my Pentium 'D' CPU temperature alarm set at 74C. Would this be considered too hot, or is it normal? With variable fans, at times, it sounds like a jet getting ready to take-off.
Thanks all,
Thanks all,
