Insert images on different sides of cube
theceo
Post by theceo »
anyone know how to put different images on the sides of a cube?
thecoalman
Post by thecoalman »
I don't see how to insert multiple images onto a single object but you could create each side as a seperate square. group them together and insert different images on each one.
pauley
Post by pauley »
Create your cube.
One of your top tool bars should have six pictures of a cube with a single side marked in blue. By default, they are all enabled.
Click on them until only one is enabled.
Go to your attribute panel and choose Texture.
Pick your image and it will be applied to that side. You may have to adjust the Wrap->Normal parameter for it to look correct (and you may need to spin the cube to see the texture on that side).
Pick another side on that top toolbar and deselect the side you just did.
Add another pic for that side.
Repeat for all sides.
Pauley
