DVD Pic $
Joni
DVD Pic $
Post by Joni »
Can someone please help. When I frist installed picshow 4 the thumbnail slide I chose showed the theme background image. It does not do it now. Also when I click on add/remove background image the line for add/remove all images is grayed out. Would appreciate any assistance.
michaeltee
motherboard: HP 82F1
processor: Intel Core I5 7400 3 GHz
ram: 16 GB DC
Video Card: Intel HD Graphics 630
Hard_Drive_Capacity: 2TB Hybrid
Monitor/Display Make & Model: Samsung S24D300
Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Re: DVD Pic $
Post by michaeltee »
Joni wrote:Can someone please help. When I frist installed picshow 4 the thumbnail slide I chose showed the theme background image. It does not do it now. Also when I click on add/remove background image the line for add/remove all images is grayed out. Would appreciate any assistance.
Hi Joni,
I'm not quite clear about what you're trying to do. Are you talking about changing the menu background? If you could sort of re-explain the problem with more detail I'll try to help :-)
-Mike
Joni
DVD Pic 4 menu problem
Post by Joni »
Hi Mike:
Thank you for replying. OK I will try to clarify my problem. After I add my pic's for the slideshow and choose the one I want to use for the slideshows thumbnail than go to theme and choose the theme I want, the slideshows thumbnail pic with theme is not showing on the organize tab with the theme-(just the pic I chose is showing) so I did not know if it would show up when I burned the slideshow. Hence I tried it yesterday and it did come up as the slideshow thumbnail after I burned it.
Also the other problem I am having is when I go into menu and click on add an image file, I can access add/remove image for this page but the add/remove image for all pages is grayed out.
Again thank you for any assistance. :)
michaeltee
ram: 16 GB DC
Re: DVD Pic 4 menu problem
Joni wrote:Hi Mike:
That's normal however you should be able to see and test the actual results in the "menu" tab on the "2 Theme" tab.
Joni wrote:Also the other problem I am having is when I go into menu and click on add an image file, I can access add/remove image for this page but the add/remove image for all pages is grayed out.
That feature would only be available if your menu is more than one page.
-Mike
Joni
DVD pic 4
Post by Joni »
Mike
Thank you very much.
