I have looked in the forum but need clarification to the process I am using below.
After Capturing the video to my hd, I normally split it nor problems and sometimes cut unwanted pieces out.
I then create a new project add, whatever mpg files to the tiimeline, and add some text, transitions .no problem.
The prob is when i add audio.
I have added mp3s with no issues, but in some instances i have converted them to wav or mpa from with ulead.
does averyone do/done this?
What method do you use?
SoME errors after adding audio and "burning" to hd to create vob files (which i later burn to dvd using nero) , I find that an offending mp3 after playing appears to "stall" the video. I generally check with Cyberlink DVD.
I have also created an audio file from the project, then create a new project , add the new audio file , including vdos + text and I get all audio sounds "repeated" after rendering , but the audio is fine.
it appears that the audio file i created includes sound from the video + my mp3 or wav files.
So after rendering i get the video+the sound , and also my audio file (including sound from the video when i created the file).
Should i be turning off the sound of the video when i create my audio file?
I know the above may be disjointed, I hope you understand what i am saying but maybe if you experts can post your procedure that'd be fine.
thanks for your time !
Mal
