Anyone know why my home video plays back jerkily. They never used to I'm sure. When I play each clip it looks ok but when I playback the finished video it doesn't play smoothly.
Thanks for any advice.
jerky playback
Hi Girly
It sounds like you are playing back the video in VS, using Project mode. If that is the case, then yes the playback may be jerky. It is just a representation of how the project will be with all edits, effects, transitions etc, being put together "on-the-fly".
Have you tried rendering the project, Share>Create Video, to see if the jerkiness is still there?
So you are viewing it in VS using Project Mode, correct? The results you are getting can be expected.
Why be reluctant to finish it? If you render, or create a video file, and it doesn't appear as it should then you can simply delete it.
You can create a video file: Share>Create Video and view the video file using Windows Media Player or some other program you may have. OR
You can create Video_TS, Audio_TS folders on your HDD, and view it using the Intervideo WinDVD player or Ulead DVD Player to view it.
To burn to your hard drive: Share>Create Disc Uncheck burn to disc, click the drop-down arrow on the right, and you will see the options to Create Folders or ISO file.
